how to get an fm and or am signal in my basement
ECGnovice
ECGnovice Posts: 31
edited July 2010 in Electronics
Hi All:
I just put together a home theater setup in my finished basement. As part of the setup, I purchased an onyko TSXR 608 receiver. I can get a few fm stations andam stations in my basement hooking up the included fm and am antennaes.
Is there a way to get better signals down in the basement without elaborate wiring. Are there other antennaes out there that are not expensicvev that I can purchase as accessories that will give me a signal?
Also, I can add Sirius radio with an accessory. Does anybody know if I will have a similar reception problem as to not get a signal down there?
Thanks for your advice.
Post edited by ECGnovice on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited July 2010
    Any type of wire can act as antenna. Run an 18gauge speaker wire upstairs to check for best placement.
  • Ric5811
    Ric5811 Posts: 400
    edited July 2010
    Bundy Fox viewing postitions?:D
    Polk RTi A7's FrontPolk CSi A4 CenterPolk Tsi 100's SurroundOnkyo TX-RZ50:)Oppo BDP 83 (Collecting dust)MIT Terminator 3 Speaker CableMIT Terminator 2 IC's (Oppo 2 chan)Signal Cable HT TWOEpson PowerLite Home Cinema 1080Hisense 55 U8GBelkin PF 60 Power Center
    F1nut Posts: 51,917
    edited July 2010
    The Magnum Dynalab ST-2 exterior antenna runs about $100.00. You won't believe what you can pick up.
  • ECGnovice
    ECGnovice Posts: 31
    edited July 2010
    I am sorry but was not sure which forum to post the thread. Wouldn't do it again... and thanks for your response!
  • ibewbrother
    ibewbrother Posts: 186
    edited July 2010
    any sirius radio has to have view of the sky....you have to put the directtv dish in the yard....right?
    "Making life enjoyable through expensive electronics." BillD
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
    Carver TFM-45 (mains)
    Carver A753x (center, surround)
    320GB PS3, 42" Panasonic G10,
    M60's as a Zone 2 off of the Pioneer in the living room
    R.I.P. Onkyo TX-NR807
    billbillw Posts: 7,730
    edited July 2010
    Best bet is to run RG-6 coax up to the outside of the house and hook it to some type of external antenna. I can be as simple as a homemade half wave dipole (use google) mounted somewhere that isn't too conspicuous, or a pre-made antenna that is mounted on the roof.
  • ECGnovice
    ECGnovice Posts: 31
    edited July 2010
    My solution as stated in more depth in another thread is to hookup my Dell Studio laptop to my Onkyo 608 thru the receiver's front HDMI port and stream Sirius and AOL radio stations.
    See my last post in the following thread: http://www.polkaudio.com/forums/showthread.php?t=103921
    Thanks everyone for your help!
