Speaker Question
dscholar2
Hi, I bought some refurbished Polk floor speakers about 12 years ago. One of the SL3000 tweets no longer work. I know the replacement is an RD0198 for the SL3000 but I am wondering if the SL3000 is the right tweeter for my speaker. I can't find a model number but I have a Serial Number, will that be able to let me know what the right tweeter is? Also, what type of fuse is correct for the 2210520 RTA 12 Filter System. I think I may have used the wrong fuse and that is why the tweet blew.
Post edited by dscholar2 on
I don't believe the RTA 12 in any version ever came with the SL3000. If it's the speaker with the exposed tweeter under the sock, then you've got the wrong tweet. If it's a conventional tower with either 2 or 3 passive radiators on the bottom then it's either a RTA 11TL or 15TL, both of which had the SL3000.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Take a picture without the grills on it.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter
