Replacing Tweeters on SRS 2.3TL's
What's the common wisdom in regard to replacing a single tweeter on the 2.3TL's? I had the Meadowlark Blue Herons and when a tweeter needed to be replaced they would have sounded horrible for over 500 hours if one side had a new one and the other side was broken in and sweet sounding.
My guess is that with this many tweeters per side it isn't as much of an issue. The purist in me would say if they were mine I'd be replacing all six at the same time and keeping good ones as backups.
All six or don't worry about doing a single?
Thanks.
Thanks.
You aren't done with wire and ready for upgrades and other tweaks until you are totally done with wire.
Keith 2006
Keith 2006
