box problem
osiris6910
everytime i screw the woofer into the box, the screw holes strip. so i am loosing air when the subs run and it sounds like whit. how can i avoid this?
osiris
Post edited by osiris6910 on
WHAT ENCLOSERS DO YOU USE IF YOU WANT TO USE THE SCREWS THAT COME WITH THE WOOFER, THAT DONT MESS UP THE SCREW HOLES IN THE BOX?osiris
