I Need a little Photoshop Help
schwarcw
Greetings!
I would like to make a photograph to use in place of the missing bezel on my McIntosh MX-113. I can't find a replacement anywhere. Anyways I have a couple of decent rez photos that I could print, cut out and mount with some "gummy glue" until I find a real replacement. The two attached photos could be "shopped" and scaled to 4" X 1" in size. The black cleaned up to be darkest black, the lettering and outline on the bezel is more of a brass color than gold.
I'd appreciate any help with this project. PM me for my email address and I can also forward the original photos. They are about 1 MB in size. Your suggestions and recommendations are also welcome!
Regards,
Regards,
Carl
Post edited by schwarcw on
Hi Sal!
Just shine from the light. I will cut a hole for the push buttons to fit through the photo bezel.Carl -
Send me a PM and I can help you out.
You may be able to just make one from scratch w/ Photoshop and/or Imagemaker vs .trying to touch-up the photos...if that was your original idea.
Let me know... -
Will this work?"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Carl, Dave is the photoshop master! He's posted things on here that are amazing. Especially when he does work like this;
[IMG][/img]
This always gets me to belly laughing and it is perfectly proportioned!:D -
lol ^^^
Carl, check your e-mail and let me know if that works. The 'brass' color is straight off a piece of brass I have. Not sure if it looks right or not for you. Not knowing the bezel font was the challenge so I preserved the font from the original photograph. -
Carl,
Check with these companies, they may be able to make new plates for you.
http://www.medibix.com/company.jsp?company_id=36047
http://cutvinyls.comPolitical Correctness'.........defined
President of Club Polk -
Thanks Jesse!
Dave and Shack both have come forward with a template. They almost look identical and both have done a fantastic job! I am thrilled with the help offered up by Forum members. Club Polk rocks!Carl -
Carl,
Jesse, these are quite intriguing. I see that they could make a static cling, aluminum or other labels with no minimum quantity. Now I am really getting somewhere!Carl -
Have you checked with Mcintosh?
I heard they had replacement parts including the faceplate available.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
