Acer Aspire One Help Needed
mufsoman
mufsoman Posts: 631
edited July 2010 in The Clubhouse
My wife has an Acer Aspire One ZG5 netbook which my son dropped. Unfortunately it landed on the corner where the power cord plugs into the edge of the netbook and broke the female plug mounted to the motherboard. I called Acer, but because its out of warranty, they were no help and referrred me to Mundocorp which handles all their parts and service. They do not have access to this part for some reason, so.....Can anyone help with how to buy just the power plug socket? I can remove the old and solder a new in place, just don't know how to spec it or where to look. Anyone have a non-working Acer netbook that could be canbalized for parts? Thanks
Parasound HCA-2003A & 2205A
Front: Rti12's
Center: Csi A6
Side surrounds: Polk Rti A1's
Atmos: Mirage Nanosats
APC H15
Power cords by Pepster, Morrow MA4 IC's, AQ Midnight, AQ Chocolate HDMI's[/SIZE]
The rest is TBD.
Post edited by mufsoman on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2010
    Check out www.digikey.com to see if you can't find the part # for the jack you need. Then you could buy from them, or someone else at that point.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • mufsoman
    mufsoman Posts: 631
    edited July 2010
    Thanks disneyjoe7. I called Digi-Key and although they carry a multitude of sockets, they admitted they have a poor track record of matching OE parts from the big manufactures. I can supply them with the plug barrel dimensions, but would also need to provide the socket mounting dimensions otherwise it may not mount properly to the motherboard. Doesn't sound like a sure thing for them to replace. That's what I get for a $200 laptop.....
    Front: Rti12's
    Center: Csi A6
    APC H15
    The rest is TBD.
  • disneyjoe7
    edited July 2010
    It maybe best to download the catalog section, and see if a connection seem to be the one. Then enter the part # and go to the manufacture to see the pdf drawings to see for sure. I sure someone makes something, but then again it could be just an OEM part. If so someone makes it just for them, and not a general part the average Joe can get.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
