Replacement woofer for LS/fx surrounds
flat 6
flat 6 Posts: 16
edited June 2010 in DIY, Mods & Tweaks
any reccomendations on what a suitable replacement for these little woofers would be? They are 4.5" and I need to replace two of my 4. PA does not have a direct replacement.
Post edited by flat 6 on
  • ken brydson
    ken brydson Posts: 9,085
    edited June 2010
    flat 6 wrote: »
    Watch for a CS350LS center as it uses the same drivers. Good luck!
  • flat 6
    flat 6 Posts: 16
    edited June 2010
    Thanks for the tip!
