SVS PB10-NSD vs CSX-15
Looking to buy a new sub and was wondering which of these two would be the best overall will be used 75% home theater and 25% music ,Thank you
SVS PB10-NSD
http://www.svsound.com/products-sub-box-10nsd.cfm
CSX-15
http://www.cadencehometheaterspeakers.com/store/pc/viewPrd.asp?idcategory=2&idproduct=17
Post edited by kiickinit on
  • packetjones
    packetjones Posts: 1,059
    edited June 2010
    I have not heard of the cadence you have listed. I have heard nothing but good things abiut the svs subs. That would be my recommendation between these 2.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2010
    I played around with the CSX15 before giving it to my son as a Xmas present. I also heard the CSX12 at a friends house. They are both more than decent subs for those on a budget and the 15 is pretty good. Like the Velo DLS5000 (or whatever it's called now), in fact it's shares the same design for the box, most of it's energy is above 30hz. It fills the room nicely and is surprisingly tuneful. The SVS will dig much deeper (18hz in room), probably won't go as loud in the midbass, but it's an overacheiver for a large 10" sub.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • danz1906
    danz1906 Posts: 5,144
    edited June 2010
    SVS all the way!!!!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
