Rear placement of FXiA4s
InsaneHz
InsaneHz Posts: 1
edited June 2010 in Speakers
Hi, I just purchased a pair of FXIA4's, however my current room layout has some restrictions. I do not have two side walls only one due to current open concept area. My concern with mounting them on the rear walls behind the listening position is that the the main woofers will be firing away from the main listening position and not have a wall for sound deflection (at least the rear right).
I have heard that if being mounted on rear walls I can switch their orientation and place the right speaker in the left position and vice versa so that both woofers are firing inwards towards the main seated area, I will also set them in bipole mode. The main listening area is about 12x14 feet, the actual room is about 12 x 24 feet.
Can anybody confirm that it is fine to do so, thanks for your help in advance.
Post edited by InsaneHz on
  • kuntasensei
    kuntasensei Posts: 3,263
    edited June 2010
    Yes, that is what you would want to do.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
