what surrounds to go with RT600i's
BRAD-TX
BRAD-TX Posts: 25
edited June 2003 in Speakers
I have the RT600i's and the 245 center channel. I am just trying to get an idea about what surrounds would go good with them. I know you can't buy the RTxxxi's new anymore, so I was wondering if the RTi's would go with them well.
I would like to upgrade all of my speakers to the LSi line at some point, but I didn't think that LSi surrounds would go well with my RT600i's.
Brad
Post edited by BRAD-TX on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2003
    The new RTi line will match well, I'd search for a pair of used RT25(i), or 35(i). OR be a team-player, and wait for the *new* line to come out (late summer?) and be the first guy on your block with some rti4's.
    However, if you are going to go LSi anyway, you might want to bag some 7's for the rears now, and work from there.
    Cheers,
    Rooster
  • BRAD-TX
    BRAD-TX Posts: 25
    edited June 2003
    thanks for your advice Russ, I may just end up going for the LSi7's, although ,making my wife understand why I need to upgrade is going to be another story.
    thanks again
  • RuSsMaN
    edited June 2003
    The proper demo with HER material should take care of that right diddy.
    Keep us posted.
    Cheers,
    Rooster
  • malikarshad
    malikarshad Posts: 527
    edited June 2003
    Crutchfield has a pair of f/x300i for $269.00. here is the link
    http://www.crutchfield.com/cgi-bin/S-Ym8P2PdLqi0/ProdView.asp?s=0&c=4&g=12200&I=107FX300IW&o=s&a=0&cc=01&avf=N.
    I guess the new Fxi30/50's would also work fine. I'm using Rt600i as my surround's and Fxi50 as my surround backs and they work perfect for me.
    My setup
    Front- Rti 70's
    Center - Csi40
    Surround - Rt600i
    Surround back - Fxi50
    Receiver - Denon Avr-3803
    Sub - PSW350 ( to be upgraded)
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • gshisme
    gshisme Posts: 1,038
    edited June 2003
    Brad,
    For H/T the RT25i's with the 600's match very well together. I highly recommend this pairing. Look around and you may still be able to find new at a great price or look for used. Bought mine from Crutchfield not too many months ago. SACD or DVD-A I don't know as I haven't experienced it yet but for H/T it is kick ****. They take everything the Rotel throws at it with a smile.
    Greg
    suds, suds and more suds!
