Ported vs Sealed Subs
I am on the hunt for a new sub as I have never felt the Polk has done the job for me. I am probably 75% movies 25% music. I have it narrowed down to three different subs, the SVS PB10-NSD and two different eD's the A5s-300 and the A3-300.
The main difference between the two eD subs is that one is sealed and the other is ported. What are the benefits of one over the other. I have only had ported subs, my previous being a Velodyne CHT 8.
If I am missing any other options feel free to make suggestions. The Epik Legend looks pretty nice but can't be had until September. Trying to keep the purchase around $600.
Thanks,
Jeff
Pioneer Elite VSX-21TXH
Monolith 7x200 Amplifier
Harmony Hub
Sony VLP-HW40ES
Visualapex 106" Electric Screen
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000
Post edited by Soccerplyr on
  • gfong
    gfong Posts: 1,079
    edited June 2010
    I have th SVS 12 inch version and it is fantastic. Movies sound awesome and it can keep up with the music listening as well.
    You would not be disapointed with the SVS and I have not heard of the other brand that you mentioned.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited June 2010
    Check out AVS forum on what people are saying about what's going on with the eD subs. I'd wait a couple of months and see what the Epik Legend can really do. Sealed subs are getting more respect in HT, thanks to bigger drivers and better amps:) Some folks prefer a cleaner bass over a booming bass. Either way, good luck with the search.
  • quadzilla
    quadzilla Posts: 1,543
    edited June 2010
    Sealed or ported can provide "clean" bass. The main difference between sealed and ported designs is that a ported sub will roll off low frequencies at a minimum of 24 db/octave below the tuning frequencies and can provide deeper useful output with the same sized box. The sealed however will give lower total extension, but requires a larger box to reach the same low frequencies. But this also gives you more extension. My preference is a sealed sub, but there are many very good ported subs out there as well.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • lanchile
    lanchile Posts: 560
    edited June 2010
    quadzilla wrote: »
    I like sealed too, The bass is much cleaner and faster than ported.;)
    Make it simple...Make it better!
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2010
    I have had both and I prefer sealed subs over ported.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • BWilberg266
    BWilberg266 Posts: 191
    edited June 2010
    Given your usage of 75/25 movies/music I would say go with the A3-300. I added an A2-300 to my setup last week and have been very pleased with it's performance on both movies and music. It has a great ability to "disappear" and really blend in just the way you want a good sub to do, but then really step up and make itself know in the high impact LFE sequences on movies. If you have all of the speaker settings, levels, and crossovers set right through your receiver I don't think you will find your bass to be lacking in definition.
    As far as "what is going on" with ED subs, I would have no concern. They have great customer service and always seem to do right by their customers should there be a need for a replacement part. There was some issue with some of the amps in their A2-300's but they have since been utilizing a newer version of amp and have seen no issues. Their subs have great bracing and use EFS, a more dense, more environmentally friendly material than the traditional MDF used by most other companies.
    I would check out the review that ED has on their site on the A3-300, the pro reviewer did a very extensive job working it on movies and music. And his previous sub was a Velodyne as well. (He actually ended up purchasing the A3-300 and using it as his new reference sub after the review)
    Any reason (besides the fact that it doesn't ship until 7/21) that you aren't considering the PB12-NSD? It would be a better comparison the the ED subs you selected.
    Main Setup
    Fronts - Energy RC-50's
    Center - Energy RC-LCR
    Rear - Energy RC-R's
    Subs - Gone...
    AVR - Pioneer SC-37
    Blu-Ray - Sony BDP-S360
    TV - Vizio E550I-B2
    Media Server - Mac Mini
  • scoobygt68
    scoobygt68 Posts: 19
    edited June 2010
    So I have a def tech trinity sub: consists of 2 powered 14" subs and 4 passive 14" radiators on the sides. Is that basically a ported sub then?
    Fronts: Paradigm Signature S8 v3
    Center: Paradigm Signature C5 v3
    Rears: Paradigm Studio 100 v2
    Surrounds: Paradigm Studio 100 v2
    Sub: Def Tech Trinity
    Display: Epson 8500 UB on 120" screen
    Processor: Yamaha rx-v3800
    Amp: Emotiva XPA-5
    Xbox 360
    PS3
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    scoobygt68 wrote: »
    a ported sub has just that a port that air is allowed to move through ect. Often they are found on the back or front of the sub, a circle in which PVC or plastic is installed.
    Sealed is just that, its sealed, no openings.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited June 2010
    Not a big sub guy here but I have yet to hear a ported sub that doesn't annoy the hell out of me.....granted I have only heard relatively cheap ones (sub 1k).
    I used to have a sealed diy Tumult that I liked.
    Regards,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • apphd
    apphd Posts: 1,514
    edited June 2010
    scoobygt68 wrote: »
    Short answer YES. At least the passive serves the same purpose as a port. What ever the total volume of air the 4 passives above can move, would have the same tuning as a port that would exhaust the same amount of air. Ports extend the low freq. response.
    Ports and sealed designs all have there pro's and con's. As replies indicate in general for music sealed are the favorites of many. For HT (LFE) ported get the nod. But there are ported that can do music good and sealed that can do HT justice.
  • danz1906
    danz1906 Posts: 5,144
    edited June 2010
    apphd wrote: »
    Agreed, A Sealed sub will need Lots of Power like the JL Audio F113 Sub-2500w
    The Ported subs(SVS Ultra-13) can get away with less power(750w) and sound
    just as Loud and go just as Deep.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Soccerplyr
    Soccerplyr Posts: 160
    edited June 2010
    Thanks for the responses. I am going to stick with a ported sub since it sounds like that would be a better choice based on the amount of time I spend listening to movies. Still up in the air on which one to go with. Might just wait until the Epik hits the market as I've read nothing but positive stuff about their product. The 300+ pages of eD stuff did have me a tad worried so thanks for the feedback on your experiences with them. Main reason for not going with the larger SVS is cost. I'm trying to keep the upgrade to around $600 including shipping. I do keep my eye on their B-stock and if one ever shows up I will definitely grab it.
    Harmony Hub
    Sony VLP-HW40ES
    Oppo BDP-103
    Music Hall MMF 2.1
    Polk LSiM 705
    Polk LSiM704c
    Polk LSiM702F/X
    SVS PB-2000
  • Polkie2009
    edited July 2010
    Soccerplyr, I believe the Epik Legend is going to be a sealed design? Maybe you can look into a used Epik of the ported design, they have a few that were well thought of. Another brand I'll throw out there just for grins in the Klipsch Synergy 12,you can probably get a used one or two for about $250-$300 each? It's a ported design and folks say it's a good bang for the buck for home theater.
  • BWilberg266
    edited July 2010
    Soccerplyr wrote: »
    I hear you on the ED stuff. I felt like I was just totally lost in all of the forums, posts, and blogs out there but now that I have one in my setup I couldn't be happier. I have to be honest though, the new dual 12" from Epik really has me curious. It look like it would be a fantastic sub.
    Main Setup
    Subs - Gone...
    AVR - Pioneer SC-37
    TV - Vizio E550I-B2
