squeezebox
sda2mike
sda2mike Posts: 3,131
edited June 2010 in The Clubhouse
i finally pulled the trigger! got the classic. does anybody use online storage for music? i'm sure i'll have lot's of questions;):)
thanks
mike
Post edited by sda2mike on
  • swegyptian
    swegyptian Posts: 316
    edited June 2010
    I got the duet a while ago, and I love it. I only use the internet radio stuff thus far, and the setup is really, really good.
    heiney9 Posts: 25,164
    edited June 2010
    sda2mike wrote: »
    thanks
    mike
    No. Are you looking to stream from the on-line storage site or just use it as a back up for all of your ripped music you store locally?
  • sda2mike
    edited June 2010
    heiney9 wrote: »
    i was thinking space-wise...i'd probably need an outboard hard drive to store all of my tunes in FLAC
    edited June 2010
    sda2mike wrote: »
    I would recommend a 500GB or more external drive. 500GB is A LOT of music even in FLAC. But it's imperative you back up your music as your library grows because if the drive fails you're back to square one and have to start all over. You could store you back-ups off site. I wouldn't stream from an off site storage site. You can get very good 500G HD's for about $60-75.
  • sda2mike
    edited June 2010
    heiney9 wrote: »
    wow! thats not too bad...thanks H9;)
  • swegyptian
    edited June 2010
    I just a deal for a 1TB HD for $39 after a mail in rebate. Tigerdirect or something similar...
  • sda2mike
    edited June 2010
    how much is 1tb?:confused:
  • maximillian
    maximillian Posts: 2,144
    edited June 2010
    If you can, get a NAS with good backup abilities. Perhaps a NAS with a raid. I think you need a NAS that can run a slimserver.
    I don't have a squeezebox but use an Xbox/XBMC and a NAS for storage. I can access all my music and videos off the NAS from either of my two XBMC machines and the various laptops throughout the house. Each machine accesses the XBMC using SMB.
    edited June 2010
    Qnap is the only NAS that can run the Squeezebox WITHOUT your PC. Other NAS units will certainly work, but the QNAP will utilize the SQB software.
    NAS units while they are the most ideal as far as secure data are very exepensive, especially if you want to do it right with something like Raid 5. DKG999 and my brother both use the QNAP. Expect to spend about $1K for the QNAP server and (4) 1TB drives.
    You can cheap out and get cheaper 0.5TB drives, but you'll only be saving a couple hundred $$$. I want to get a QNAP because I think it's the absolute best solution but I can't justify $1K for it.
    Actually you can probably do it for about $750. The one DKG999 bought is the upper model. Which suits his needs because he uses it for other things beside just a music storage device. His has the faster processor. You can get the next model down however and it would do a great job as well.
  • eeagle
    eeagle Posts: 226
    edited June 2010
    I use a Seagate Expansion 2.0 TB USB 2.0 Desktop External Hard Drive
    Pick one up at Amazon for $140 shipped sometimes even less.
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
  • dkg999
    dkg999 Posts: 5,647
    edited June 2010
    I went with the QNAP TS-459 Pro because my NAS will support more than just music storage. I have a growing number of digital photos between myself and my daughter, and want other storage and internet login capabilities to support my businesses.
    With all the work it takes to rip, tag, organize and store your music collection I wouldn't cheap out on back-up storage. I also wouldn't look at a NAS server as just a music-only investment, as the ability to connect via wireless to my NAS from any laptop or other pc and have a common storage place for files, then be to get to those files via the internet, is just unbelievably nice.
    DKG999
  • Demiurge
    Demiurge Posts: 10,874
    edited June 2010
    sda2mike wrote: »
    1 Terabyte = 1,000 Gigabytes.
    I can't wait for Petabytes. :D
    1 Bit = Binary Digit
    8 Bits = 1 Byte
    1000 Bytes = 1 Kilobyte
    1000 Kilobytes = 1 Megabyte
    1000 Megabytes = 1 Gigabyte
    1000 Gigabytes = 1 Terabyte
    1000 Terabytes = 1 Petabyte
    1000 Petabytes = 1 Exabyte
    1000 Exabytes = 1 Zettabyte
    1000 Zettabytes = 1 Yottabyte
    1000 Yottabytes = 1 Brontobyte
    1000 Brontobytes = 1 Geopbyte
  • lectronicjunkie
    lectronicjunkie Posts: 299
    edited June 2010
    This will keep you going for a while. Not bad for $90.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148406
    It's all in the detail.
    :cool:
    HT Setup:
    Samsung PN50D550
    Onkyo TX-SR805
    Samsung BD-D6700
    Fronts: RTi10's
    Center: CSi5
    Side surrounds: RC65i's
    Rear surrounds: FXiA4's
    Sub: Velodyne CT120
    Outdoor: Atrium 45's
    Pictures here
  • Demiurge
    edited June 2010
    I just realized sda2mike probably meant how much does 1TB cost, not how big it is. :o
  • sda2mike
    edited June 2010
    Demiurge wrote: »
    no..i was asking about size;) turns out a tb is beeg!
    edited June 2010
    sda2mike wrote: »
    It is! The thing you have to realize with the SQB software is you can only assign one folder which means one drive so if you buy a smaller drive and fill it up you can't just address another drive.
    The Squeeze Touch does have a USB connection so you can swap drives, but I'm not sure how that works or what the access time is, etc.
    So buy at least a 500GB or better yet a 1TB then you never have to worry especially if you will use the drive for other stuff besides music storage.
  • eeagle
    eeagle Posts: 226
    edited June 2010
    heiney9 wrote: »
    There is a workaround for this limitation. Simply place a "shortcut" to any other directory or drive on your computer or network, in the directory/folder you set for the SQB Server and the Server software will scan it too.
    HD space is inexpensive so go for a large drive.
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
  • szhleppy
    szhleppy Posts: 320
    edited June 2010
    heiney9 wrote: »
    The Touch accesses music on the drives fairly quickly...it reads through the files just as quickly as any standard laptop, then it's ready to go! I picked up a couple 2TB drives, but the NAS solution looks like it would be much better long-term.
    edited June 2010
    The NAS is the best solution, but the most expensive as well.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2010
    With the QNAP NAS I just setup you can have up to 4 2TB drives, which with 8TB total in a RAID5 config I think you get 3.7TB or so of usable space. I went with 4 1TB drives initially which gives me around 2.6TB of usable space. When 2TB drive costs and reliability improves I'll go with them at some point.
    DKG999
  • szhleppy
    szhleppy Posts: 320
    edited June 2010
    dkg999 wrote: »
    Sorry to go off-topic from the OP...this solution is pretty intriguing though.
    dkg...can you point me in the right direction on this?
    With the NAS solution, can I designate certain folders as accessible to everyone who can access my wireless network (movies, music, some pictures...for any laptop or AppleTV...which will be replaced with a HTPC in the near future), while designating other folders (documents for work) as password protected?
    With the NAS solution, would I be able to access these folders while traveling?
    I have been considering cloud services for data storage, but the cost isn't necessarily reasonable for 4TB of data...most of which is movies that I don't need to access while traveling. I would still be concerned with the loss of data if my house burned down while traveling, but this certainly looks to be a better solution than stacks of external hard drives. Appreciate any thoughts....
  • John30_30
    John30_30 Posts: 1,024
    edited June 2010
    swegyptian wrote: »
    I almost pulled the trigger on that one. It just keeps getting ridiculouser and ridiculouser.
    sda2mike wrote: »
    about 3000 cd's in lossless unless my math lobe is failing.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2010
    szhleppy wrote: »
    I am a novice at this, but this is what I think I know and have learned. With the QNAP NAS you can create users and assign user permissions and rules. I haven't looked at password protection yet. As long as you have a static IP address externally, you can login from the internet and get to your data. There are so many options in the QNAP interface it's almost mind-boggling. You can also set it up as an SFTP server, wireless printer interface, etc. I would google QNAP and spend some time on their website. I bought mine based on reading the info on the website and recommendations of other CP members.
    DKG999
  • szhleppy
    szhleppy Posts: 320
    edited June 2010
    dkg999 wrote: »
    Thanks dkg...I took a look at their website and it's a little overwhelming. I'll take a closer look when I get back from vacation next week...probably start by searching through other CP member posts on this topic. Looks like a great tool and would love to hear more updates as you spend more time with it.
