haunted hot tub stereo
superjunior
a few days ago my wife told me the radio in the hot tub was on. its basically a car stereo built into the side of the hot tub with speekers behind the headrests. I've been known to do some strange things while sleepwalking so I figured maybe that was the case. so yesterday morning I walked out of the house and the damn thing was on again. I shut it off and went back in the house. 15 minutes later I went back outside and sure enough it was on again. this morning I walked outside to water the garden and it was on. Damn! no kids or pranksters around here. anyone have any ideas what might be going on?
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one
Post edited by superjunior on
Maybe your hot tub is a time machine and your guests from the future don't turn your radio off after they use it.
Solid theory, really. -
at this point I won't rule that out, damn time travellers...panasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
Hehe, funny -
Lay off the drugs.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Is it the kind that can be operated with remote? Perhaps that's the reason. My neighbors were always turning on my ceiling fans and lights until I changed the code. Of course, I'm not sure you can do that in this case.
Mischievous children? -
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
mdaudioguy wrote: »Is it the kind that can be operated with remote? Perhaps that's the reason. My neighbors were always turning on my ceiling fans and lights until I changed the code. Of course, I'm not sure you can do that in this case.
no remote, no kids...panasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
I think the cat turned it on, you cannot trust that animal.........
What type of switch turns it on? Does it have an auto-on function tied to anything the hot tub does?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Who ya gonna call??If you can't hear a difference, don't waste your money.
Is it a Sony head-unit? Because those things tend to suck.
What type of switch turns it on? Does it have an auto-on function tied to anything the hot tub does?panasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
A remote sensor you aren't aware of is a good guess; try researching the unit by model number to see if in it comes with one in other applications.
After that I would wonder if there is any contaminates that got inside and is causing a short that turns-on the unit.
Are the knobs on the outside of the tub? Can you put a cover on it?
.....What if a squirrel is using it to get up and down the side of the tub?
If you leave it on, does it turn off on its own as well?
Try to find a way to get another variable.
"If you eliminate the impossible, whatever remains—however improbable—must be the truth."
- Sherlock Holmes......and later - Spock. -
I think condensation on or in the radio causing the problem.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
