inverted center?
dfledezma
dfledezma Posts: 148
edited June 2010 in Speakers
This might have been asked before, but couldn't find any info by doing a search.
I have a CS10 and I just saw in the description from Polk that the center can be flipped upside down. Is this true? Any problem by doing this?
thanks
Post edited by dfledezma on
  • Ric5811
    Ric5811 Posts: 400
    edited June 2010
    dfledezma wrote: »
    thanks
    It's true, I am doing it right now, no problem doing it. Just reverse your grill:D
    Polk RTi A7's FrontPolk CSi A4 CenterPolk Tsi 100's SurroundOnkyo TX-RZ50:)Oppo BDP 83 (Collecting dust)MIT Terminator 3 Speaker CableMIT Terminator 2 IC's (Oppo 2 chan)Signal Cable HT TWOEpson PowerLite Home Cinema 1080Hisense 55 U8GBelkin PF 60 Power Center
  • nedh84
    nedh84 Posts: 143
    edited June 2010
    Yep I'm doing it as well. No problems. Looks and sounds better :)
    HT and Music Rig
    Receiver- NAD T765 HD
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds side- Polk Audio Monitor 60
    Sub- Polk Audio PSW505
    Windows 7 Media Center
    T.V.- 40" Sony Bravia LCD 1080P
    Blu-Ray- 80 GB PS3
  • packetjones
    packetjones Posts: 1,059
    edited June 2010
    I have my csia4 inverted right now. It is below the tv so this helps with the sound stage. You will have no issues at all.
    Good luck
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • dfledezma
    edited June 2010
    thanks! I'll try it then.
  • texas ed
    texas ed Posts: 139
    edited June 2010
    I have the lsi center channel.I don't think it would work for me.The box is rectangular and would only lower the tweeter for me.Would you flip on an odd shaped center or what am I missing.I flipped an older cs series center to change the angle but it looks like it would not help me.My shelf spacing comes into play as I can't really adjust the angle....eddie
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited June 2010
    dfledezma wrote: »
    Why wouldn't it be? If you read it online somewhere, but it wasn't in the manufacturer's documentation, then by all means question it.
    Or, perhaps you really just wanted to see if others were doing it. :confused: Never mind, carry on... this just struck me as funny, and elicited a response. No offense intended! :)
  • McLoki
    McLoki Posts: 5,231
    edited June 2010
    texas ed wrote: »
    I am sure the LSiC can be flipped over (mine is) but that is not to say it works best for you in that orientation.
    Michael
  • dfledezma
    edited June 2010
    mdaudioguy wrote: »
    No problem at all!! you're right just wanted to know if anyone else did. I think it was a bit weird for me the first time I read it.
  • dfledezma
    edited June 2010
    texas ed wrote: »
    Yes, the thing is that the CS10 has an angled top, so it makes a difference in orientation if you turn it over, but perhaps there is no difference at all with the LSiC as it is rectangular.
