sda--sunfire question
w_coyote
w_coyote Posts: 66
edited June 2010 in Vintage Speakers
I just purchased a sunfire cinema grand amp(200x5@8ohms). My question is this a common ground amp and ok to run sda's? I have done a search and found lots of info on both the sunfire and sda's and I see where some use them with their sda's but could not find anything about if it was a common ground or not. This is probably a slly question and been covered before but I could not find it. I have not received the amp yet,just trying to make sure so I don't screw any thing up. Thanks in advance for your help.
Post edited by w_coyote on
  • vmaxer
    vmaxer Posts: 5,117
    edited June 2010
    You are safe to use it, I use one myself!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • BAD ASP
    BAD ASP Posts: 361
    edited June 2010
    vmaxer wrote: »
    excellent match. I enjoy mine a great deal.......:D
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
    nooshinjohn Posts: 25,465
    edited June 2010
    My 2.3TL's are driven by a Signature 425x5 right now and is an amazing combination.
    Enjoy the Music!
  • maandjojo
    maandjojo Posts: 293
    edited June 2010
    They are a match made in heaven.
    Joe
    Joe
