Harman Kardon dvd5
hotwheelman
Quick question....I have a friend that has this and is going to give it to me, the only problem is that it needs repair. When you plug it in the standby light comes on and when you press the power button to switch it on..........no workee. It is the dvd,cd changer and is in mint condition.
I don't think that it is the power supply as there would be no lights at all if it were....right? Maybe a bad power switch is to blame, wonder how much it would cost to repair this thing.
Any comments or suggestions would be greatly appreciated.
Cheers,
Mike
Cheers,
Mike
"Its worked so far but we're not out yet."
"Hey big man let me hold a dollar"
Just fishing here as I don't know the HK players, but for most of the ones I have seen, if the power switch is "off" the unit is all the way down, not even in standby.
Can you tell if the power switch is mechanical or electronic?
Since players are controlled by a chip, it's possible the one in your player got zapped by a power spike.More later,
Tour...
Vox Copuli
Good thing you're getting it for free. I have one and some disks it says the disk is incompatible with the player. This happens to me sometimes with rentals, but has happened with some I've bought! I can sometimes get them to read by switching the main power off, then on, sometimes changing disk positions, but nothing always works.
Unfortunately, it always seems to act right when I take it to my local authorized HK repair shop.
BTW, forget listening to CD-R's.Denon 1803 Receiver
Denon HDCD CD player and DVD Player
DTV HD Tivo Recorder
AR Pro Series Interconnects
Kimber Kable
48 inch Magnavision HD projection
Polk CS350 center channel
Polk RT10s
Polk RT/fx
AR 12" slot loaded sub
(Mirage Omnisat system almost complete)
