3 x LC265i for LCR Configuration
SoundEngine355
SoundEngine355 Posts: 12
edited June 2010 in Speakers
I am in the process of setting up a 5.1 in-wall system in my new theatre room. I am toying with the idea of using 3 x LC265i for LCR Configuration and a pair of LC80F/X for rears. The LC265i centre would be mounted horizontally. I know the LCiC is the centre for the LCi series, but I think the LC265i would be better as it is a 3way vs 2way and has a dedicated midrange.
Just wondering if anyone has mounted the LC265i horizontally before?
SE
[ Home Theater ] 3 x LC265i for LCR and LC80fx rears plus Velodyne DD15 subwoofer using Denon 3808a processor with custom 5 channel amplifier and Oppo BDP-83 player.
Post edited by SoundEngine355 on
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2010
    I would vote against it as the speaker wasn't designed that way. It would probably sound OK but the dispersion will be weird. If you could keep it standing normal I would say go for it.
    Just my .02.
