Speakers w/Different Ohm Ratings vs. SC-07
mufsoman
Can I use surrounds rated at 6 ohms (nominal) with Rti12's and Csi A6 rated at 8 ohms with a Pioneer SC-07? Are there issues with running different ohm ratings with the same AVR? Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Denon 3800
Parasound HCA-2205A
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Post edited by mufsoman on
Just make sure everything is calibrated and you'll be fine.
