Want Memory!
PerfectCreature
Hi, so I just bought a Sony DSC W370 camera. I don't have any good memory for it, and buying it brand new is just ridiculously expensive.
So, it says it takes SDHC Memory Class 6 or higher, or Memory Stick Duo (HG) or Memory Stick Duo. They must be Mark 2.
Anyway, if anyone has any of them, 4GB or higher please let me know. (I would love a 16 or 32 GB one!)
Thanks so much.
Thanks so much.
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Post edited by PerfectCreature on
Keep your eyes peeled at the office supply stores.
OfficeMax
Office Depot
Staples
They often run pretty killer deals on those proprietary-assed Sony cards.
Don't be afraid of the non-Sony branded cards, they work great in my PSP.
Another point, 8GB should let you take a LOT of pictures, and since you're not using these cards to store long continuous files, like movies, why not just buy 2 or 3 smaller capacity cards in place of one big one? Seems like a far better value.
edit: Missed the bit about it taking SD cards as well as MS.
Screw the MS, go SD- much cheaper. And definitely check the office supply stores, I got an 8 GB micro SD for less than $18.00 a couple months ago. -
Only place I have is a staples....maybe I'll be able to pick one up cheap, I'll take a look. I got a 4 gig yesterday but it only holds around 500 pics, and I take a lot of pictures, and movies and such. The camera takes movies in 720p so that's great, as for the SD cards, it won't recognize anything lower than a class 6. Which is rather upsetting since my old camera has a bunch of class 4 cards.
Oh well, thanks for the tip, maybe it will be winner.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
I've been a shopper at MicroCenter for several years. They usually have memory at value pricing.
I did a search on high capacity SD cards. They do have some that are class 6 and class 10:
http://www.microcenter.com/search/search_results.phtml?Ntx=&Ntt=&Ntk=&N=4294966791+4294957946&Ns=P_RetailPrice&Nso=Ascending&sht=Any&prt=NewProduct&web_group=RT2000i - Front
CS1000p - Center
F/Xi-A6 - Surround
DSW PRO-600 - Sub
Pioneer VSX-94TXH
Panasonic TC-P54G10 -
Thanks.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
