Cable specs
acmf74
acmf74 Posts: 937
Can someone please explain in layman's term :) what
Nom. Capacitance -
Nom. Conductor DC Resistance
are and what they do for digital coaxial cables?
Post edited by acmf74 on
  • chuckt62
    chuckt62 Posts: 33
    edited June 2010
    Both contribute to signal loss, though it's debatable whether it's significant over normal lengths. The lower the spec the better.
  • acmf74
    acmf74 Posts: 937
    edited June 2010
    chuckt62 wrote: »
    Thank you!
  • yepimonfire
    yepimonfire Posts: 256
    edited June 2010
    also keep in mind that coax is digital, meaning it will either work right or not work at all, generally unless your running 200ft of cable it won't matter.
  • acmf74
    acmf74 Posts: 937
    edited June 2010
    Since I own some Blue Jeans and Signal cables (and have been very happy with them), I decided to try out our friends at Monoprice. Since alot of the higher end cables tell the specs of their cables I asked Monoprice's about theirs. They came back with this:
    Thanks for your patience while we got the information you requested.
    The information we received from the department that gets that
    information is as follows -
    Nom. Capacitance - 54 pf/m
    Nom. Conductor DC Resistance - 0.22 ohm/m
    Nom. Inductance - you can ignore this, becasue the testing result of
    the cable will be different from putting the cable in straight and
    cercle
    I have 3 of their premium cables and have them connected from my AVR to my Cable Box, Blu-Ray player for audio AND use one for my sub-woofer cable. After listening to some movies/TV I am VERY pleased with the results. Hope someone else can find the above specs/info useful.
  • afterburnt
    afterburnt Posts: 7,892
    you can ignore this
    mhardy6647 Posts: 35,312
    edited January 2020
