OEM speaker stands for Monitor 7, questions on DIY
anhedonia
Greetings
I'm getting ready to overhaul a pair of 7b's, new caps, resisters, etc., and I'd like to build up some stands as well.
What is the recommended height and tilt for these things?
Thanks.
Thanks.
Post edited by anhedonia on
Well, I think my stands are original, and the dimensions are as follows:
Bottom plate is 3/4" thick, height to top plate from surface of bottom is 10+1/2" (back) and 11+1/16" (front) clinometer reading on iPhone was ~7 degrees of tilt.The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche -
Here is a thread with that info:
http://www.polkaudio.com/forums/showthread.php?t=24335&highlight=stand+monitor
post #23
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Jim has a much better reference, thank you search functionThe secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
Thanks. I think I'll go a different route with mine, something the speakers can sit on without any need to screw anything into the cabinets. I have a very uneven floor in my basement due to the original house owner insisting on a way too steep a slope to the drains so adjustable feet is a requirement. The plan is to make for an easy project and once I find that box of round tuits I'll post the results. They'll be about 8" high to center with the recommended 6 degree tilt.
