Horrendous Officiating
I-SIG
'Nuff said.
Wes
Wes
Link: http://polkarmy.com/forums
Panasonic TH-42PHD8UK 42" HDTV | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Wyred 4 Sound STP/SE Pre | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
Yep, USA should have 4 points now instead of 2.For rig details, see my profile. Nothing here anymore...
Koman Coulibaly (the ref) has plenty of detractors in Africa. Not sure what the hell FIFA was thinking when they selected him. No matter what he screwed that game up big time. Findley's completely bogus yellow card (which will keep him out of the next game) was as bad as the disallowed goal. Coulibaly definitely needs to find a new line of work.
Let's put Coulibaly on the no fly list!
I'll settle with 3-2. Bradley should officially lodge a protest. At least get what Coulibaly was ruling for.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Definitely... I meant it was as bad of a call, but in terms of the outcome, I'd prefer to have the winning goal back if I had to choose among the several questionable calls in the game that should have gone a different way. -
When the ref won't tell the players what the call is you know something is not right.....
WesLink: http://polkarmy.com/forums
Panasonic TH-42PHD8UK 42" HDTV | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Wyred 4 Sound STP/SE Pre | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Don't they have a ref. tribunal and arbitration panel?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
That ref will never set foot on a World Cup pitch again.
