SDA SRS 2 Setup on an angled/windowed wall
mmadden28
I know the general recommendation is to position SDA's as close to a rear wall as one can to get the best bass response out of them, but I have a question about the impact of placing them on an angled wall since that is the optimum location I was planning for moving my rig too-but before I go through all the trouble I wanted to get some opinions here first. Also there is a window back there.
Take a look at the layout attached--any thoughts on if it might work out or if it will be too crazy. I'm sure I might give it a try anyway but...
And if this might work, should I pull them out a bit more into the room at all?
Thoughts?
Note: This isn't necessarily to scale and my side walls are farther away than shown--it was just a real quick drawing.
Thanks!
Thoughts?
Thanks!
____________________
Pool: Atrium 60's/45's
Post edited by mmadden28 on
How big of a room do you have. If it is in the area of 16ft.by 16ft. I would think you would have plenty of bass out of the SRS 2's. Try out the speakers the way you have planned. I bet you won't find much loss of bass at all, the way it is setup in the diagram. SRS 2's have a heavy bass sound to them to begin with. Let us know how you make out.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
Got any pics of the room? I'd give it a try and see, you'll never know until you try it.
You won't know without trying. Just by looking at the image, there's no way to give a definite answer. What size is the room?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
It's a basement--not square like in the image-more rectangular like a U-I just threw that together real quick to show the angled wall.
I'm currently running the rig on the opposite wall, but they are not optimally placed against the rear wall if near a rear wall at all).
I'll see if I can scan my blueprints in and take a pic or two of the location tonight.
I guess I'm concerned more about the angled rear walls being a known bad thing for SDAs or not, considering placement is so critical with them.____________________
Pool: Atrium 60's/45's -
All this time posting/drawing/scanning and you could have tried it for yourself already. :P"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
