Polk 5jr (4 ohm) Ported
Bruferrit
I picked up a pair for $8.00 at a garage sale they are in great shape (9 out of 10). I am woundering about how to use them with my Pioneer vsx-d711 receiver. The manual says that the receiver is looking for 8 to 16 ohm speakers, could i run the speakers in series as a center channel? any advise would help.
Bruce
Bruce
Post edited by Bruferrit on
Welcome to Club Polk.
Are you saying that they are ported ???
They would work as centers. A dedicated center has different crossover points. Better off with a dedicated center IMO. -
Yes they are ported (no radiator).
Could i run the speakers in series as a center channel? any advise would help.
Bruce
That's the only way you should run them without a new amp. -
Stand corrected. Never new they had a 5jr that was ported. -
Original 5JR's were ported. The 5JR+'s (SL2000) and later 5JR+ Series 2's (SL2500) had a 6.5" passive radiator.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
Well the sticker on the back says 5JR.
Are there any home built cabinets or any drawings showing the existing cabinet to make a copy that I could make out of MDF or a Hardwood?
Not that I know of; most all of that would be hand-measured, I'd assume. Outer dimensions are one thing, but driver positioning is another.polkaudio Monitor 5 Series II
