Entabulator?
Knucklehead
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Post edited by Knucklehead on
Expert Moron Extraordinaire
Turboencabulator
JH Quick
[From The Institute of Electrical Engineers, Students Quarterly Journal 25]
For a number of years now, work has has been proceeding in order to bring
prefection to the crudely conceived idea of a machine that would work to not
only supply inverse reactive current, for use in unilateral phase detectors, but
would also be capable of automatically synchronising cardinal grammeters. Such
a machine is the 'Turboencabulator'. Basically, the only new principle involved
is that instead of the power being generated by the relaxive motion of
conductors and fluxes, it is produced by the modial interactions of magneto-
reluctance and capacitive directance.
The original machine had a base-plate of prefabulated amulite, surrounded by a
malleable logarithmic casing in such a way that the two spurving bearings were
in direct line with the pentametric fan, the latter consisted simply of six
hydrocoptic marzelvanes, so fitted to the ambifacient lunar vaneshaft that side
fumbling was effectively prevented. The main winding was of the normal lotus-
o-delta type placed in panendermic semiboloid solts in the stator, every seventh
conductor being connected by a non-reversible termic pipe to the differential
girdlespring on the 'up' end of the grammeter.
Forty-one manestically placed grouting brushes were arrranged to feed into the
rotor slip stream a mixture of high S-value phenyhydrobenzamine and 5 percent
reminative tetraiodohexamine. Both these liquids have specific pericosities
given by p=2.4 Cn where n is the diathecial evolute of retrograde temperature
phase disposition and C is the Chomondeley's annual grillage coefficient.
Initially, n was measured with the aid of a metapolar pilfrometer, but up to the
present date nothing has been found to equal the transcetental hopper dadoscope.
Electrical engineers will appreciate the difficulty of nubbing together a
regurgitative purwell and a superaminative wennel-sprocket. Indeed, this proved
to be a stumbling block to further development until, in 1943, it was found that
the use of anhydrous nagling pins enabled a kyptonastic boiling shim to be
tankered.
The early attempts to construct a sufficiently robust spiral decommutator failed
largely because of lack of appreciation of the large quasi-pietic stresses in
the gremlin studs; the latter were specially designed to hold the roffit bars to
the spamshaft. When, however, it was discovered that wending could be prevented
by the simple addition of teeth to socket, almost perfect running was secured.
The operating point is maintained as near as possible to the HF rem peak by
constantly fromaging the bituminous spandrels. This is a distinct advance on
the standard nivelsheave in that no drammock oil is required after the phase
detractors have remissed.
Undoubtedly, the turboencabulator has now reached a very high level of technical
development. It has been successfully used for operating nofer trunnions. In
addition, whenever a barescent skor motion is required, it may be employed in
conjunction with a drawn reciprocating dingle arm to reduce sinusoidal
depleneration.Expert Moron Extraordinaire
<embed id=VideoPlayback src=http://video.google.com/googleplayer.swf?docid=5125780462773187994&hl=en&fs=true style=width:400px;height:326px allowFullScreen=true allowScriptAccess=always type=application/x-shockwave-flash> </embed>Expert Moron Extraordinaire
And, for some reason, this came up as "Related":
<embed id=VideoPlayback src=http://video.google.com/googleplayer.swf?docid=8787452113268513375&hl=en&fs=true style=width:400px;height:326px allowFullScreen=true allowScriptAccess=always type=application/x-shockwave-flash> </embed>Expert Moron Extraordinaire
