Best bang for the buck ICs
Rev. Hayes
Rev. Hayes Posts: 475
I'm looking to clean up my wire mess a bit and at the same time upgrade my interconnects. I'll be needing:
~9' for the phono pre > preamp
currently :crap red and white
~9' to connect my preamp >amp
currently :monster AV cable
~2' to connect dvd > preamp
currently :old but nice gold terminated rca's from the University surplus
~2' to connect cd > peamp
~9' to connect sub > preamp
currently :monster (not the sub dedicated kind just normal low end monster AV cable)
AND (don't hate me people) a nice 1/8" phono to RCA for the quick Ipod fix
Any suggestions are welcome but be aware I do not intend to spend a great deal on this. I am not currently capable of even thinking about MIT or anything like that. Let's say I might spend $200 but I really don't want to.
Also I'm quite willing to make this a DIY project but only if the cost benefit ratio matches what I think my down time is worth ;)
This is a serious request for suggestions/advise. I'm well aware of the potentially inflammatory nature of this subject and I ask that this thread not devolve into mudslinging. I personally believe that quality ICs just make sense but everyone has a cut off point as to what they get out of any upgrade. My cut off point is strongly weighted against cost as stated above.
Sounds good to me...
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited June 2010
    Hey Rev.
    I'd suggest looking for some Signal Cables on the used market. You might be able to replace what you've listed for close to $200. It might take a while, and you'll probably not find every cable you need in one sale. Be patient, and they'll surface.
    heiney9 Posts: 25,724
    edited June 2010
    Signal Cable I/C's and if you are into DIY, Canare Star Quad 4S11 speaker cable with banana plugs or spades here at $1.19 per foot that's about as inexepensive as it gets. I use this in my office rig. Nice stuff for not a lot of coin.
  • Rev. Hayes
    edited June 2010
    I think I'm ok with my speaker wire (ultralink audiophile reference series 10 gauge) but I have just bookmarked that link for when I get around to wiring up the man shed proper like. Thanks H9
  • Rev. Hayes
    edited June 2010
    Hey Rev.
    Just got done reading a number of audiogon posts on these cables. Paired with your used suggestion these sound like a good choice. One issue... I saw that a number of people said that Signal cable has a way of "warming" or "calming down" the sound. I would prefer to avoid that as I am currently getting a bit whiny about the "laid back" sound of my system.
    Is this something to worry about or is this just nitpicking what would certainly be an improvement over the status quo?
    edited June 2010
    Rev. Hayes wrote: »
    No problem, but I just realized your specific question was concerning I/C's.....still Signal Cable is great bang-for-the-buck. Some will recommend Mono-Price and I would pre-empt that rec and say stay away as it won't be any better than what you have.
    When you get around to doing speaker cables (and those matter; sometimes even more) the Canare is hard to beat.
    Good luck
    edited June 2010
    Rev. Hayes wrote: »
    There isn't much difference between Analog I's and Analog II's but in my experience the Analog II's are tad more laid back than the Analog I's. How they compare to what you have already; I couldn't say other than either of Signals will be smoother and better defined I'm sure. If you find they are too laid back you can flip 'em very easily.
  • Rev. Hayes
    edited June 2010
    I hope some more people weigh in but Signal is sounding like the one. I realize that my price point is rather restrictive so the field is probably pretty small.
    Anyhow...
    I should also point out the fact that I could go with balanced I/C's between the preamp and amp. I tried this once before with a pair of cheapos I had tangled up in the closet from back in the day when I played music on something other than the stereo. I had been using the monster RCA's and when I switched to the the XLR (in the hope that it might provide a signal boost) it ended up sounding worse. There is a button on the back of the amp to select between the two inputs and I had a friend help me "blind" test them. There was a notable drop in presence and clarity. Was this just a result of the fact that these were cheap mic cables intended for a practice space or what? Could the sound have been affected by having both types of cables plugged in at the same time? I would be willing to try the balanced again if you more experienced folk could explain why the first try was such a flop.
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2010
    You should also look at Blue Jeans Cable & Monoprice for affordable alternatives.
    http://www.bluejeanscable.com/index.htm
    http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10218
    I use IC's from both & they get the job done.
  • Conradicles
    Conradicles Posts: 6,437
    edited June 2010
    I like SignalCable.
    You won't here much about them here on this forum, but IXOS is another great bang for the buck cable in my experience.
    edited June 2010
    I made some DIY speaker cables out of the IXOS Gamma raw cable. Nice sounding cables. Assessories4less sells a full line of IXOS stuff and I have bought from them several times with great success.
    Click on Audio Cables...........some good deals at Assessories4less
  • concealer404
    concealer404 Posts: 7,440
    edited June 2010
    I'll throw Audioquest Sidewinders out there.
  • Rev. Hayes
    edited June 2010
    yeah, it's too bad the pair on the FM today sold before I even saw the post.
    I might have given that a shot.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited June 2010
    +1
    I would say either Signal Cable Analog I's or Sidewinders. Having owned both types, I preferred the Sidewinders. And yeah those were my 2 pairs I just sold, they went quick!
    Keep a lookout, they'll surely come up.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • concealer404
    edited June 2010
    Rev. Hayes wrote: »
    Keep your eye out. You can usually find them even new for plenty reasonable prices. :)
    But the fact that they sell fast on these forums should show you something. ;)
    edited June 2010
  • kcoc321
    kcoc321 Posts: 1,788
    edited June 2010
    +4 on the Sidewinders. I like mine. I like my AQ Quartz better, but the Sidewinders get me by.
    Rev, keep your eye out at your local Goodwill or eq...
    I just scored 3 pairs of new style 2m Sidewinders for.......$10 :D
  • Rev. Hayes
    edited June 2010
    heiney9 wrote: »
    Damn dude! I should have you do my grocery list too. :D
    The discounted green's look like a good deal. Anyone listen to these before?
  • daboyz
    daboyz Posts: 5,207
    edited June 2010
    Bang for buck? Signal Analog II's without a doubt,end of story. Just buy and be happy.
  • GEBBY44
    GEBBY44 Posts: 939
    edited June 2010
    I'd even suggest some Belkin PureAV Silver Series IC's if you can find them. They are discontinued but some are still available on Ebay I think. They are great sounding IC's that were better then Signal Analog II's in my opinion. Made of OCC copper like the Outlaw PCA IC's for a cheaper cost.
  • Rev. Hayes
    edited June 2010
    Thanks to everyone for the suggestions!
    I just placed an order for the belkin's that Gebby44 suggested as I could get the lengths I needed well within my budget.
    16' for $34 I just couldn't say no.
    I also (pending verification) bought dpowell's Signal analog 2's in CP's flea market moments ago.
    I figure at least this way I can play around with them and hear for myself whether it would be worth it to me to save my pennies for the longer runs.
    I'll be sure to report back with my impressions.
    Thanks again,
    Ashley
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    Also look at the audioquest that are below the sidewinder I forgot the name but has a blue jacket. Still a good ic and will run less than the sidewinder. He next step down after that is the alpha snake that is a black jacket I think not as good IMO but still does a great job
  • dhart86
    dhart86 Posts: 1,594
    edited June 2010
    another vote for the audioquest sidewinder. I have a couple pairs of the AQ sidewinders and the AQ copperheads. Great IC's Signal's are good as well.
    Look for audioquest on the used market
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • Norm Apter
    Norm Apter Posts: 1,036
    edited June 2010
    kawizx9r wrote: »
    +1
    +1
    I use MITs on the main 2 channel, but the components of my home theater system and secondary 2 channel rig are linked together exclusively with SC Analog IIs and AQ Sidewinders. I'm very pleased with each of these and have absolutely no intention of upgrading. As others have said, these come up fairly often in the CP Flea Market and Audiogon. But just as they come up frequently, they are snatched frequently (a good sign) so just keep checking. If you're in a rush but have some time on your hands, then maybe follow H9's DIY suggestion.
    2 Ch.
    Parasound Halo A23 Amp
    Parasound Halo P3 Preamp
    Parasound Halo T3 Tuner
    Bada HD22SE tube CD Player
    Magnum Dynalab Signal Sleuth
    Magnum Dynalab ST-2 antenna
    polkaudio Lsi9s (upgraded cross-overs)
    MIT Shotgun S-3 Bi-wire Interface Speaker Cables
    MIT Shotgun S-3 Interconnects (3)
    IegO L70530 Power cords (3)
    HT
    Denon 2808ci AVR
    polkaudio RTi A5s (fronts)
    polkaudio RTi A1s (rears)
    polkaudio Csi A6 (center)
    Signal Cable Ultra Speaker Cables
    Signal Cable Analog II Interconnects
    F1nut Posts: 52,406
    edited June 2010
    I never found Signal cables to be warm.
  • Rev. Hayes
    edited June 2010
    So, what I've ended up with for the moment is:
    Signal Cable Analog II's connecting my DVD/cd player to the pre
    Belkin Pure AV Silver Series 2 connecting my phono pre to preamp and preamp to amp
    (these are 16' runs)
    Listening to a burned cd copy of The Asylum Choir's Look Inside- I like this as a reference album because it seems to have everything, lush stings, blaring trumpets, wacky sound effects, rock vocals, honky tonk piano..... but I digress
    Well the first thing I noticed was that my bass was much tighter. Not nearly a boomy as it had been. In fact it seemed significantly set back and quiet in the sound stage.
    Second thing I noticed was the right channel tweeter cutting in and out during the intro to track 9. This bit is just the sound of a church bell tolling and the tape is slowly sped up over the course of about 15 seconds. As the pitch reached a certain frequency the tweeter (only on the right side) would cut in and out. there was also a good bit of hiss coming out as well, a much louder hiss than the other channel.
    I switched my speaker cables (right to left) and the issue followed to the other speaker.... Switched the IC's (right to left) and no change.
    :eek:PANIC:eek:
    Must be the amp. shut everything down for the night and decided to take'r apart the next day and clean/shake it down.
    Now I come home this afternoon and decide to try and rule out a few more
    things. Played track 9 and didn't hear the same cut in/out issue but the hiss was still there. Swapped all the cables around and at the this point it looks more to be the cable itself or my preamp.
    My sound stage seems much wider but also not nearly as deep.
    Instrument isolation within the stage is better but the bass is hiding.
    Is this the Burn in Blues or what?
    Has anyone else experienced this during a cable change or is it repair time?
    edited June 2010
    The only I can say is which way you hear it is correct? Perhaps with the new cables the recordings sound closer to how they were recorded. Revisit the bass issue in a couple weeks. At first since it's not as bloated it can seem like it's not there (perhaps that's the way it was recorded) after getting away from the exaggerated, bloated bass you might realize you actually "hear" more natural, organic bass, like it was intended.
    P.s. Give it some time for more evaluation.
  • Ric5811
    Ric5811 Posts: 400
    edited June 2010
    You said the problem switched to the other speaker when reversing speaker cable? Then it's your speaker cable. Could be a loose connection. Or bad wire.
    Polk RTi A7's FrontPolk CSi A4 CenterPolk Tsi 100's SurroundOnkyo TX-RZ50:)Oppo BDP 83 (Collecting dust)MIT Terminator 3 Speaker CableMIT Terminator 2 IC's (Oppo 2 chan)Signal Cable HT TWOEpson PowerLite Home Cinema 1080Hisense 55 U8GBelkin PF 60 Power Center
  • WilliamM2
    WilliamM2 Posts: 4,829
    edited June 2010
    Ric5811 wrote: »
    Not if he just switched the wire at the amp end. Then it's probably the amp, as he suspects.
  • Ric5811
    Ric5811 Posts: 400
    edited June 2010
    WilliamM2 wrote: »
    That is the big unknown, is it not?!:D
  • Rev. Hayes
    edited June 2010
    Ok, it seems I should address the "unknown"
    I did some serious cable swapping and worked back through the system from the output end (speakers) all the way back to the source (cd player).
    Final verdict is that my $65 Toshiba bestbuy POS DVD player was the cause of the hiss. No surprise there. It is by far the weakest link in my current system. I usually listen to vinyl so I wasn't too worried about upgrading until now.
    The high frequency cutting in and out stopped happening after the first day so I still think the new cable was somehow having an effect on the signal, but it would appear that the for the most part the higher quality cable was just bringing the fault to the foreground.
    Overall the sound I'm getting out of my speakers now is an improvement. As I said above the sound stage is more detailed and wider but somehow doesn't seem as deep. The base has tightened up a lot and is a vast improvement over the muddy boom I was getting out of my Lsi9's. Perhaps with some more burn in (currently only about 15 hours or so) it will get even better.
    The title of this thread was not an accident...
    In the search for the best "Bang" for my buck I feel pretty good. The belkin cables at $34 for 16' were almost obscenely inexpensive. I needed the long run due to some odd space restrictions in my living room. The Belkin Pure AV Silver Series line, phased out of production but still available on ebay, was just what I needed. If anyone else has a similar situation then I would defiantly call these to attention as for me they really fit the bill.
    I would still like to try some of the other cables that were suggested above. The price of the most of the other cables mentioned is roughly twice what I paid for the Belkins and may very well provide twice the sonic quality. Even at that higher price I think that the Signals and the Audioquests likely qualify as a Best bang for the buck IC I just can't say so myself as I haven't had the chance to listen. If anyone out there has some long runs of the other cables mentioned and would like to do a temporary swap then I could draw some more conclusions:D
    This strikes me as a potentially useful thread for anyone looking to improve their system with cables on a budget so please continue to put out more suggestions if you have some. I may have my problem solved for the moment but I'm not going to just stop trying to make it better and I think we could always stand more threads about how to make your Polk speakers sing like they should without breaking the bank. This is the sort of valuable discussion that brought me to this forum, really got me going in this hobby, and subsequently ruined my life:eek::p:D.
    Thanks to everyone at Club Polk,
    Ashley
