Holy cow! Power "cords" make a difference!
Serendipity
Well, not quite...
Recently, in this thread (http://www.polkaudio.com/forums/showthread.php?t=102110) I installed more dedicated circuits for the audio gear direct to a 50A subpanel.
The following circuits power the gear:
1. 20A w/AFCI breaker for audio components
2. 20A w/AFCI breaker for the video components
3. 15A w/AFCI breaker (spare)
4. 15A dedicated circuit for the subwoofer
5. 15A dedicated circuit for the gaming consoles
6. 15A dedicated circuit for the projector
7. 15A dedicated circuit for the Onkyo and amp
8. 30A 230V for the Friedrich air conditioner
Without changing ANY of the power cords, the largest difference I heard was in the sub - it was much more powerful, accurate, and hit harder. I had to reduce the gain on the back of the sub to make it 0db when playing the test tones compared to the front speakers. Also, I didn't hear the usual slight pop/hum when turning on the lights in the room, which I used to have before.
So what do you think I will experience when I start changing power cords?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
Serendipity wrote: »So what do you think I will experience when I start changing power cords?
A lighter wallet. Or, a higher debt:income ratio. Take your pick.
Seriously, the biggest thing I noticed in my 2ch setup was a more "weighty" sound, but without actually getting louder or more dynamic. Also, it seems to me that there is a reduced amount of background noise, which is to say it's all but gone, as there was not much before anyway.
If you want, I have several PCs you can borrow next time we meet up.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Well, considering the vast majority of the wire is from the outlet to the breaker panel, and since I used a larger wire (12-2 vs. 14-2, for example), wouldn't it make sense to use a heavier gauge power cord going from the outlet to the gear?
I just don't have much gear with removable power cords... the PC, sub, and projector are the only ones that come to mind... and the Xbox 360.polkaudio RT35 Bookshelves
