Wall mount speakers
k140db
k140db Posts: 10
edited June 2010 in Speakers
I was debating on doing in wall speakers but have read alot of articles giving not so positive reviews. Now i'm leaning to wall mounted speakers. Ultimatley i would like to have everything off of my floor except the subwoofer. It just looks alot cleaner and spacious than having floor speakers taking up space. Anyone here try the polk OWM3 and OWM5 series? Just wondering how the sound quality would be for a 5.1 surround sound set-up.
Thanks,
Kevin
Post edited by k140db on
  • McLoki
    McLoki Posts: 5,231
    edited June 2010
    Is there a reason you are not considering any other bookshelves? (I have LSi7's on wall mounts and they work great.
  • k140db
    k140db Posts: 10
    edited June 2010
    I'm not leaning toward anything. Just saw these online and was wondering how they are. Plain and simple.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited June 2010
    k140db wrote: »
    Another important factor to determine what kind of sound you can get is your budget.
    What were you thinking of as far as cost on speakers and mounts?
  • k140db
    k140db Posts: 10
    edited June 2010
    I was looking to spend around 1200-1500 on all the speakers.
  • Erik Tracy
    edited June 2010
    k140db wrote: »
    Look for a deal on Polk's ebay site for RTiA1s for fronts and rears, a CSiA4 or CSiA6, then the remainder on a good Internet Direct sub (Epik, Elemental Designs, HSU, etc).
    But - that's just my internet expert armchair advice... :D
