Tech question about the RC80i's
Ok, Tech guy's, here's a question for you. The RC80i's are biwireable (I don't need a bunch of reply's how this is a bad thing because I have two amp's). My question is how are the X-Over's set up in these speaker's. We have a tweeter (excellent one at that) and two same size driver's below. How are the X-Over's set up? One to the tweeter and another to the bottom driver's. OR, One to the tweeter and top mid driver with the lower driver being fed from it's own. This is important because I don't want to waste one amp just feeding the tweeter. That would be over kill.
Post edited by Imspun4u on
Which model are you talking about? The RC80i has a single midwoofer and coaxially mounted tweeter.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Yes, you are correct and I don't know where my mind was on that question. Totally different speaker. My bad and I apologize. The speaker I mean't to refer too was the RT18 and how the x-over was set up with it. The driver compliment is 2-6 1/2 (16.5cm) and 1 - 1" (2/5cm) tweeter. I see the x-over frequency is 2.25KHz. What can you tell me about this setup? John
