Need Layout Idea for my room
a250Rlover
a250Rlover Posts: 2
edited June 2010 in Speakers
Looking for your ideas on what kinds of speakers I should use and WHERE to mount them. My room seems to be speaker location challenged.
The room is prewired for 7.1 in the ceiling. All drops are located with the couch being in the center.
Requirements:
1) Must have great sound and imaging. I'm willing to pay the price.
2) Fit well with the room and be surround compatible.
3) Would like to have great sound from the front channels for music. If I mount my speakers to the ceiling I will only get good imaging on the couch.
** Please see attached pic of my room.
Options:
1) Flush mount ceiling speakers using pre-wiring- since they're so far away I don't think I'll like the imaging for music at all. AND sound will probably be horrible for surrounding rooms
2) Bookshelf speakers LSi7 or LSI9's mounted from the ceiling and using existing pre-wiring. Is it possible to mount LSi9's from the ceiling or would this look like a huge block sticking out from the ceiling?
3) Get creative with other locations on the wall or soffit? (see pic)
4) I can't figure out any floor standing speakers for this room....you can see how ugly my existing ones are.
Post edited by a250Rlover on
  • a250Rlover
    a250Rlover Posts: 2
    edited June 2010
    Anyone? Bueller....Bueller :rolleyes:
  • kawizx9r
    kawizx9r Posts: 5,150
    edited June 2010
    Hey a250Rlover,
    one question that comes to mind is, how big is the living room? How much open area do you have behind the couch if any (is it an open floorplan that extends out to a dining room area/kitchen?)
    I ask because, if it isn't that large of a room a proper 5.1 will do just as well if not better than a 7.1 in a medium sized room. More speakers isn't always better. ;)
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
