Music System for Tata Nano
![rameshiyer](https://w3.vanillicon.com/3a88005f5f720b7d34d74ae5aeb43e81_100.png)
rameshiyer
I would like to install a good music system for my Tata Nano. Kindly suggest good music system and speaker set for my Tata Nano. You may be aware that Nano has limited option in this regard. I would like to install ICE with bare minimum alteration in the existing set up. One suggestion is Pioneer 4290Sd and Polk Audio DB 691. Kindly suggest a good ICE after taking into all aspects of Tata Nano.
Post edited by rameshiyer on
Polk warranties in India are dodgy at best. The products though are great while they last. Take your pick.
Dear Arun
Can you make it clear. I am looking a valuable suggestion from you. -
hi Rameshiyer - since the nano is not available anywhere else in the world yet except india, you'l have a tough time getting good suggestions unless you give us more details and maybe post some pictures of the stock speaker locations.
(Usually i'd suggest a good set of seps for the front such as the DB6501 and a nice amp to power it as a good minimum. Ofcourse you'l still want the upgraded HU to work with as well) -
If the indian distributor can't take care of you to your complete satisfaction, try calling Polk directly. I assure you they are the easiest people to deal with and will bend over backwards to make sure you have a big smile on your face after
(PM me if you need direct contact details) -
Dear Topper
Please visit www.tatanano.com, I hope, you may get some idea. I feel, speaker can be placed in try behind rear sit.
