Need some advise to select the best amp for my HT system!!!
buccidiego
buccidiego Posts: 75
edited June 2010 in Electronics
Let me give you the components that I already have:
Front Speakers: 2 RTi12 (500 wpc)
Center Speaker: 1 CSi5 (200 wpc)
Side Speakers: 2 FXi5 (150 wpc)
Rear Speakers: 2 RTi8 (250 wpc)
Subwoofer: PSW 505
As the AV Receiver, I'm planning to get the Pioneer VSX 1120 (not yet out there) (offers 120 wpc)
I need some advise from more experienced people (I new in this hobby) to select the best amplifier that would fit the components I stated above.
I was looking for a 5 channel amp with approx 20o wpc to combine with the AVR. I've done some research and the short list that I came up with is:
1- Parasound HCA-2205A
2- Rotel RMB 1095
3- Parasound 5250
I think I would be able to run the 2 front, center and 2 rear with the amp. The 2 front would be biamp with the AVR, and the 2 sides would be fed by the AVR (reducing the AVR load).
Really appreciate your comments.... Thanks in advance!! :)
Post edited by buccidiego on
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2010
    Just run the whole system off the new external amp. I recommend a Sunfire, and for this price they can't be beat. They perform very well, stay cool and should run that setup no problem.
    http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1280849571&/Sunfire-Cinema-Grand-Five-Ch-2
    edited June 2010
    All your selections look good to me, so does the Sunfire. I'd only bi-amp the RTI-12s...the power amps should be enough for everything else IMO.
    Looks like you've done your homework.
    BTW, I like Parasounds, myself.
    cnh
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2010
    All the amp suggested will do the job just fine. And with that much power, biamping really isn't necessary.
  • buccidiego
    edited June 2010
    Thanks for the comments so far!!
    Any other contribution to the question? Appreciate....
  • buccidiego
    edited June 2010
    What do you think about the Emotiva XPA-5 (200 wpc). Is this comparable with the others? Would it be a better choice to get this "new" or any of the other "used" in good condition?
  • cfrizz
    edited June 2010
    Any of the amps INCLUDING the Emotiva will get the job done in spades.
    You will now get dozens of naysayers telling you to get ANYTHING other than the Emotiva.
    It all comes down to what YOU are comfortable with. If you would feel better buying a brand new amp, then get the Emotiva & be happy, if you don't mind buying used, then get any one of the other 3 amps. All will do a splendid job.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited June 2010
    That Sunfire definitely looks good and there's no doubt a lot of fellow Polkies here who are very happy with them. I have to ask what kind of budget(we all have them) are you looking at to spend on the amp or amps?
  • ken brydson
    ken brydson Posts: 8,988
    edited June 2010
    Did they add pre-outs to the 1120? I don't think the 1020 had them...
  • cnoat
    cnoat Posts: 315
    edited June 2010
    Between rotel,adcom, and parasound having tried them all.I am partial to parasound.Very neutral imo.Have never had the pleasure of a carver in my ht room.
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
