RTi A3's
JimAckley
JimAckley Posts: 1,138
edited June 2010 in Speakers
So after changing lots of factors including new MonsterCable speaker cables, running absolutely no bass boost in my computer or receiver, I've come to notice that my RTi A3's have a peak in the response somewhere close to 140 Hz, give or take a bit. Any insight as how to fix it? They are kinda sorta in a corner, and I have a hunch that might be the culprit, but I don't really have the option to move them right now.
- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
Post edited by JimAckley on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited June 2010
    JimAckley wrote: »
    Hmmm...I think you have identified the issue - placement. I had my RTiA3s on wall mounts and noticed that there is bass reinforcement the closer you get them to the wall - more so if they are in a corner.
    Can you put any fabric or other acoustic absorbing material behind the speakers. The rear facing power port probably is compounding the issue....not sure if you can plug that or not - may want to pass that one by Polk CS.
    Does your receiver have any auto-calibration to even out the response?
    Do you have a Graphic Equalizer - maybe you could some freq notching adjustments to cut back the 140Hz band.
  • JimAckley
    edited June 2010
    Well I'm going to get them up on the wall as soon as I can find a table of some sort to replace my armoire. It's height and the fact that my TV resides on top of it is totally in the way of where I want to place my right speaker, but once I get a table there, all of that will change. I guess what I was trying to find out is if that was a natural characteristic of any sort or if it's because of my environment
    - Computer Rig -
    - Main Rig -
  • JimAckley
    edited June 2010
    I discovered it's the location, which is a shame because I love my corner setup...
    - Computer Rig -
    - Main Rig -
    edited June 2010
    Isn't that what they always say: location, location, location. Just kidding...I also thought it a bit ODD that that speaker would have any peak in that region? Glad to see you solved the problem.
    cnh
