PS Audio - Duet 4-Outlet Power Conditioner
Conradicles
Conradicles Posts: 6,372
edited June 2010 in Electronics
Looking to replace my power center for the 2-channel rig and don't want a "component style".
I want one that can be placed on the floor behind my rack, has at least 4 outlets and under $200.
PS Audio is a brand that I have no experience with, so I was hoping to get some feedback about this unit. Anybody have any hands on experience with this one or like models?
http://www.psaudio.com/ps/products/detail/duet-power-center?cat=power
http://www.audioadvisor.com/prodinfo.asp?number=PSDUET
Post edited by Conradicles on
  • Ern Dog
    Ern Dog Posts: 2,237
    edited June 2010
    Well I have the next model up, the Quintet. Works great in terms of protection. I do notice a slight loss of dynamics when using it versus plugging components directly into the wall. I'd have to do some more tests to know for sure though.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2010
    I have the Quintet and the Duet. I like the quality of PS Audio gear and it seems they've got technology that backs up their hype. I haven't noticed any degradation in SQ or dynamics, however my Duet has been used for a secondary system where I might not notice it as much. For the current sale prices, highly recommended.
    DKG999
    F1nut Posts: 51,927
    edited June 2010
    If you can find a PS Audio UPC-200, get it.
  • Conradicles
    edited June 2010
    Noted and thanks Jesse.
  • Conradicles
    edited June 2010
  • RCFGuitars
    RCFGuitars Posts: 159
    edited June 2010
    I have a Duet and a Quintet behind my rig. I had the Duet first, and was using it along with an APC unit for a few months. The quality of the PS Audio is excellent, and it worked better in my rig than the APC, so I picked up a Quintet. I have a dedicated line for my system, so my need for voltage regulation is not as critical. The PS Audio units seem to deliver cleaner, quicker power than the APC and Furman’s that I have used in the past.
    In the manual PS Audio suggests using a higher quality cable than the one they include. I upgraded my power cable, and I agree with their recommendation. With the better cable, I have compared the PS Audios to a direct connection to the wall, and have noticed no loss in dynamics, or anything else. So, to get the most out of it, I would advise adding that to your budget. For the price in your links, it’s a bargain.
    Primary System
    Polk Audio SDA SRS 2.3TL (RDO198,Sonicap/Dayton/Mills,CardasCCGR,Mye Spikes,DynamatX,Driver Rings,Ben's IC,Bi-Wired)
    Polk Audio CSiA4 x2 (C)
    Polk Audio FXiA6 (S)
    Polk Audio RTiA3 (RS)
    Polk Audio FXiA4 (FX)
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Technics/KAB SL-1210M5G w/ Denon DL-160
    Parasound Halo P7
    OPPO BDP-83
    Panasonic TC-P65V10 65" Plasma
  • Conradicles
    edited June 2010
    Thanks. If I already have a dedicated 20 AMP circuit, I'm wondering if I should just go with the PS Audio Juicebar II...$119 from Audio Advisor and later on get a PS Audio Soloist for my wall outlet. Decisions, decisions lol.
