I think I bought Monitor 7's
Lman
Lman Posts: 4
edited June 2010 in Vintage Speakers
at a flea market for $10 but what are these tweeters (see photo)? After doing much reading I have no idea what these are or what the previous owner was thinking - taping the tweeters in place. Can someone shed some light on this?
Also, notice that the surround on the driver is damaged. Can I repair this with silicon, replace the surround or do I need a replacement?
The speakers also have external fuses which customer support told me should be 1 amp 250 volt fast blow. The cabinets are in rough shape but I would like to restore these so any help/advice is much appreciated.
Once I decide what to do about the tweeters and the driver I will update the crossovers.
Lou
097.jpg 526.8K
Post edited by Lman on
  • Ricardo
    Ricardo Posts: 10,636
    edited June 2010
    This is right up there with the cardboard sub.
    That is not the original tweeter, and also the mid woofer is not original. The cabinet does look like a Monitor 7 though.
    IMO not worth the $10. You'd have to spend over $100 just to get the original drivers, and who knows what else was done to them.
    Welcome to Club Polk!
    SOPA
  • concealer404
    concealer404 Posts: 7,440
    edited June 2010
    I'd burn those and try again.
    Welcome! :D
  • dkg999
    dkg999 Posts: 5,647
    edited June 2010
    They would sound better if you replaced the inferior electrical tape with audiophile quality duct tape.
    Those are just awesome! I would send them to Polk HQ as a start for their hall of shame!
    DKG999
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited June 2010
    Get another set.
    I would throw them in the Gulf and hope they plug the oil leak.
  • Conradicles
    Conradicles Posts: 6,138
    edited June 2010
    Ricardo wrote: »
    hehe:)
  • Lman
    Lman Posts: 4
    edited June 2010
    Thanks, I figured that they were too far gone but had to ask.
    Lou
    edited June 2010
    You know I just saw an episode of the Mythbuster's Duct tape extravaganza. I think they forgot to do SPEAKERS!
    PASS!
    cnh
  • schwarcw
    schwarcw Posts: 7,341
    edited June 2010
    Don't be too hasty. If the woofers, passive radiators and crossover are intact. And if the cabinet and grill cloth look to be in pretty good shape. You can get a used pair of SL2000 tweeters for about $20, and do a little carpentry work to patch the botched tweeter replacement.
    Even with the SL2000 tweeters the Monitor 7's are a terrific sounding pair of speakers. If you like the sound and the tweaters may be a little bright. A new pair of soft dome replacement tweeters from Polk would cost you about $100.
    Did the Polks come with the stands?
    Carl
  • helipilotdoug
    helipilotdoug Posts: 1,229
    edited June 2010
    Those tweeters are real beauties! At least you could sell the XO's and PR's to recover your $10 if you don't feel like repairing them.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • DaveHo
    DaveHo Posts: 3,536
    edited June 2010
    schwarcw wrote: »
    Look closer, that isn't a Polk MW driver either. Frankenpolks at their best. If the passives are in OK shape, sell them to recoupe your $10 & junk the rest.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited June 2010
    Junk them...
    Not really. save for the passive, nothing looks original. I especially like the tape around the tweeter... some seriously professional install work there.
    Realistically, as has been said above, they're not worth the money to fix up... as you can usually find fully operational sets for less than money it would take to buy the parts individually.
    At $10, you did okay. Passives and XO's are worth that easy.
  • Vette C6.r
    edited June 2010
    Read above.
    Already been said 3 times.
  • gwh
    gwh Posts: 1,451
    edited June 2010
    Looks like a micro screen shaver in the tweeter hole, sometimes those can go for big $.
    G
    HT:
    Martin Logan Motion 40
    Martin Logan Motion 50XT
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Def Tech Reference Sub
    Yamaha RX-A3070
    Signal Cable speaker wires & interconnects.
  • JohnLocke88
    edited June 2010
    Vette C6.r wrote: »
    Read above.
    YOU read above. I acknowledge in my post that I'm repeating what's been said above. I'm not some shmuck trying to get my post count up, so back off.
    Snarky comments contribute less than redundancy.
    Peace.
  • Lman
    Lman Posts: 4
    edited June 2010
    I pulled the crossovers and more creativity (see photo). Also what is not shown is the speaker wire taped to the mid leads.
    I removed the duct tape and the tweeters were held in place by silicone. The mids are radio shack replacements.
    Anyway, I've decided that given all the abuse these speakers have taken I am going to restore them - even if I don't like the sound it will make a good story.
