101/85/rum & coke
Rivrrat
Outside temp
Pool Temp
My choice right now
Have a good Fri Night!
Pool Temp
My choice right now
My equipment sig felt inadequate and deleted itself.
Post edited by Rivrrat on
Lucky ****.
It's about 60-ish and pissing down rain like it has been for the last 6 months in Seattle. It's days like today I wish I was back at my old alma mater. Bear Down, Wildcats! -
Outside temp
Pool Temp
My choice right now
Hopefully it will be below 90 when I take the field about 840!
WesLink: http://polkarmy.com/forums
Panasonic TH-42PHD8UK 42" HDTV | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Wyred 4 Sound STP/SE Pre | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Wes
At least it'll be dark. I've dealt with too many of my players not getting off the field before they went into heat exaustion.:(My equipment sig felt inadequate and deleted itself. -
Lesse .... 74/72/Lionshead
Outside/inside/beer
82% humidity, currently. Some t-storms to the south... close enough to see the light show, but I don't think they'll clip us.Ludicrous gibs!
