Micro Seiki M-505 Tone Arm
Deathjester
Deathjester Posts: 24
edited June 2010 in Electronics
Anyone know where parts are available for this??
I need the tone arm rest bar. It mounts on top of the lift piston.
~~Dj~~
Main System:
Onkyo TX-SV717PRO
Onkyo Integra M-504
Onkyo Integra EQ-540
Pioneer CT-F1250
Micro Seiki DD-40
Polk Audio 5A's 10A's
Post edited by Deathjester on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited June 2010
    Are you talking about the plastic hook or the whole upright? The only parts available will be salvaged units. You could make the plastic part out of a slice of tubing and bit of glue if you are handy.
  • Deathjester
    edited June 2010
    No; I just need the cross-bar part. I think it was plastic. And a tiny screw held it down to the lift piston. But the screw is broken off in the piston.. It's so small that I cant figure out how to get it out of there. No screw extracters that I know of go that small.
    ~~Dj~~
    Main System:
    Onkyo TX-SV717PRO
    Onkyo Integra M-504
    Pioneer CT-F1250
    Micro Seiki DD-40
