SDA 2 identification
bluecomet
bluecomet Posts: 1,118
edited June 2010 in Vintage Speakers
I am about to sell my SDA 2 speakers and just want to make sure what model they are. They have the one tweeter but are blade/blade. Are they SDA 2A's or can they be SDA 2B's. I know most SDA 2B's are pin/blade.
Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
Post edited by bluecomet on
  • Hamatym
    Hamatym Posts: 269
    edited June 2010
    Hey old Buddy, I think I got an easy way to check! Take out the "Stereo" driver and see what part number it is. Looking at the SDA Driver chart:
    1) If it's a MW6510, then it's 2A's (The dim. driver would be the same)
    2) If it's a MW6503 then it's 2B's (The Dim. is MW6511)
    I hope this helps!!
  • bluecomet
    edited June 2010
    I pulled the stereo driver and it is the MW6510. So it looks like it is the SDA 2A's. Thanks for the assist buddy.
  • Hamatym
    Hamatym Posts: 269
    edited June 2010
    Anytime Bcomet!
    pitdogg2 Posts: 27,019
    edited June 2010
    I always thought SDA 2A had 3 drivers and 1 tweeter was there 2 different 2A's?
  • Hamatym
    Hamatym Posts: 269
    edited June 2010
    From the list, it looks like original SDA-2 had (3) MW6501 driver's...then the 2A's are as listed above. Maybe there were some transitional models made that showed this?
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited June 2010
    If you have 6510s, they are SDA 2A. One tweet, two mids (both 6510) post a pic if you want further confirmation.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    No, you're thinking of the original SDA 2's. The original 2's had 3 MW's and 2 tweeters each. The tweeters were the "dimensional" tweeters that all of the earliest SDA's had.
    2A's have 2 MW's, which are both 6510's, and one tweeter. The 2B's had 2 MW's, but used one 6503 and one 6511 in each, along with a single tweeter.
    There were also differences in the cabinets. The 2A's had all wood grain cabinets, with "pedestal" bases that put the cabinet itself a few inches above the floor. The 2B's had cloth sides, and wood top/bottom caps, such as the SDA 1C's. Most 2B's were pin/blade, but the earlier ones were blade/blade. There were also some transitional 2B's that used the 2A style cabinets, and blade/blade IC's.
    As others have said, you've got 2A's. I've got a pair of 2A's myself, and they're some fine sounding speakers.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited June 2010
    thanks guys just checked myself and both mine also 6510mw. I was always led to believe i had SDA2b's when in fact they are 2A's. Just goes to show your never to old to learn:rolleyes:
