DR.Spec check out this sweep chart
faster100
I don't know if i did it correct as the meter i am still kinda new at.. far as the -10 on the 60 and 70 scale, what do they represent.. and on each level it only go's up 6+ db, so how do you get the full 60-70 db settings, 70-80 so forth, anyways i did the sweep and typed it into your spread sheet that you sent me, i will try and attach it for you to look over if you would. Thanks again and let me know what this 404 is looking like
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
I cant attach the excel file,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I guess print screen will work,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
and the rest of the pageMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
For example, on the 70 scale, -10 represents 60 dB, 0 represents 70 dB, and +6 represents 76 dB. So you have a 16 dB range for each scale setting.
If you can't get a reading on a given scale, switch to a lower or higher scale to keep the needle within the -10 to +6 region and read the number accordingly.
As for the read-out, looks about what I expected, some peak around 50 Hz and extension to about 35 Hz and then a quick decline below that. If you want to do another sweep just to be sure you were reading the numbers correctly, I can take the raw numbers, add the correction factors, and run a graph and post it if you want.
To save time, you might want to start at 20 Hz.
Doc"What we do in life echoes in eternity"
SVS -
Thanks alot Doc, Ok i will do the test when i can run it again today and post the results, I really appreciate it..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
faster100 how did you do the sweep. Did you have all speakers playing, or just the sub? Where did you place the meter, was the meter placed at ear level & at what angle? I have the test tones that I downloaded & burned to cd & I want to do check my system,, On your chart what dose the 0 deg & the 180 deg meen? is it the angle of the meter? Anything else that I may need to know to do the sweep? Or is there a site to go to that explains how to do it? Thanks in advance!
0 Degree is the phase switch on the sub, I have a tripod that i set the meter on at ear level slightly tilted up (45 degree) i think.
all front speakers playing, they are set to small so it doesnt really effect the mains, I start the burned cd, and everytone that plays i watch the meter and write it down, Dr.spec has a excel spread sheet he uses and i just added my sub to the list...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Actually, it does affect the mains if you use an 80 Hz crossover to the sub. That's one of the nice things about the 80-100 Hz tones; they are played primarily from the mains, and you can also evaluate the effect of the phase control at the crossover point.
In my room, 0 degrees = an 8 dB null at 80 Hz. 180 degrees = no null at all at 80 Hz.
SVS -
Thnaks for the response. What readings should I be looking for? It there a certin reading I would want through out the range? Or should I have a steady increase all the way up? What vol level do I use? I think I should be using the same vol that I use to set up my speakers. thanks for the help!
