SVS Subs....
Grimster74
Grimster74 Posts: 2,576
edited June 2003 in Speakers
Since I've joined these forums all I have heard is everyone praising SVS subs, I know, living a sheltered life. So, my question is with my current setup (Dual PSW450 Subs) what exactly would I gain out of purchasing 1 or 2 SVS subs. I know I would gain incredible low end but would I have to swap out receivers, etc.
Post edited by Grimster74 on
  • dorokusai
    dorokusai Posts: 25,577
    edited June 2003
    Plug n PLay Grim, no changes needed, except for maybe your room arrangement.
    You may also have to super glue all your stuff down so they don't vibrate onto the floor.
    Nice receiver btw :)
  • Grimster74
    edited June 2003
    Oh, almost forgot, say I wanted to go with just one sub instead of two. One, would one SVS sub do the job and if so which model should I be researching. Thx.
  • faster100
    faster100 Posts: 6,124
    edited June 2003
    depends on what size room you have?? e-mail svs and tell them your room size and they will pick a sub, Tom over at svs is great and i have also e-mailed him and got info.. its that easy
    http://www.svsubwoofers.com/
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
