5.1 HT setup for small room
JCP
JCP Posts: 1
edited May 2010 in Speakers
Hi guys,
Need some help in setting up a HT in one of my smaller rooms in my apartment.
The room size is H-10.5', W-12.5', L-13.5'.
Plan as of now:
TV - 47" LED LCD
Receiver - Denon 1910 (read a lot of good reviews about it and also gives the option of going 7.1 at a later stage)
Speakers - Polk RTi A3 for front and rear and CSi A4 for center
Sub - Polk PSW 125
I'm just confused if i should be getting these speakers or scale it down to A1's because of the size of my room.
I plan on having the viewing distance at around 9'.
Can anyone please give any suggestions if this sounds like a good HT setup or it is too much for this size room.
Thanks again in advance.
Post edited by JCP on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited May 2010
    I fully support the RTia3s. From what I've heard, the 1's don't sound nearly as impressive.
    That being said, if you find yourself pressed for budget, you can also check out the RTi line, as they're quite similar and can be had for less.
    Welcome to ClubPolk! Look forward to hearing your impressions, and seeing photos!
