RM6750 vs. rm705
dmxsoulja3
Hello,
Was just wondering if anyone could compare the two other then specs what advantage is there to going with either of these systems, the older system seems to have larger speakers, but is the newer system designed better? Just looking for some help before purchasing.
Thanks, J
Thanks, J
Post edited by dmxsoulja3 on
If you look at newegg the RM510 seems to be a good bang for the buck with slitghly more porer (as far as the sub, double toe power).
The RM6750 is of priced cheaper since it is a vintage and uses the bottom of the crop as subwoofer.
As far as I am concerned I am noto keen of plastic enclosures... The RM510 can not be found on Polk site... not sure if ths is a mistake, could it be the RM10 5 pack? If so my ,02 would be the aluminium enclosure is also a plus over the 6750 but just my opinion.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=polk&Page=5
Cheers!
TKDARE TO SOAR:
