Is it worth upgrading subwoofer IC
samnor
I havent been able to get a clear perspective on this. I can understand folks upgrading their IC's between preamp-amp (lower capacitance, air as a dielectric and the whole 9 yards) but with regard to subwoofer connection from the preamp, is it worth the upgrade to say a bluejeans lc-1 or some other "audiophile" cable or will the monoprice version suffice.
Fronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup
Post edited by samnor on
You're going to get responses on both sides of the fence, here.
IMO, there are better things to spend your money on than cables. Especially if the cable is not carrying powered signal. Stick with whatcha got. -
if you can see a point of passing a low level signal over a cable from preamp to amp, why can't you see the point of a low level signal from preamp to sub's internal amp?Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
As with any cable, capicitance is one of the most important things. This is especially true with a sub cable, since when the cable's dielectric discharges, it will tend to smear the bass signal. Some people are sensitive to this, some aren't. That said, you can find close out deals on the Acoustic Research Masters Series sub cables for as low as $10 for the 15 ft version. Try that, and if you hear a difference, then decide whether you think it's worth upgrading further. I went from AR's low end sub cables to the Master Series and heard a difference that I liked better, and it cost me around $35 for two cables with shipping and am pretty happy.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
A sub cable will carry far less info than the preamp to amp and its usually the highs and the mids in my ears that tend to be affected, the sub is handling bass period.. So its not the same comparison... Quadzilla made a point about bass being smeared so sure, low frequencies can potentially be affected by an inferior high capacitance cable but my question was whether the difference is so obvious when you upgrade a sub cable vs upgrading the preamp-amp connection...
Quadzilla, I'll try out the ar cable as you suggested. Thanks....Fronts: Wharfedale diamond 9.6
Polk multimedia speakers for PC setup -
Some people are also sensitive to low frequencies. I'm one of those people. Even though it's less information as far as the total range of frequencies, the levels are the same as from a pre to a power amp, so the same issues are typically encountered. Any hum, especially in the lower frequencies, will usually be magnified since the sub is only producing low frequencies.
I just checked, and amazon has the AR Masters MS253 25' cable for $20 w/ free shipping and it's in stock, and the 15' is at $10 w/ 8.50 shipping through a seller from amazon's site. Last 15' available though.Turntable: Empire 208
Arm: Rega 300
