i have a ground loop problem
goingganzo
have a ground loop problem. i fixed it with cheater plugs. is that the olny way? my 2 amps that have this problem bouth use a 3 prong plug. and my recever uses a 2 prong plug.
Post edited by goingganzo on
Does your amps have a ground lift switch?
Sometimes a ground loop will be caused by an ungrounded cable TV system.Best Regards, Cliff -
what is that? my cable sysstem is grounded befor the powered amp for the 8 way spliter
