tennis balls?????
K-daugh
I have an onk ht-rc180 avr,sony5-disc dvd player, comcast digital hd cable bx,and 6 TENNIS BALLS....each ball will be sliced in half and painted black....one half for each crner of each component as a footer.....round side up. will this give sonic improvement and or picture improvement .....also i can have an infinite amount of mdf 3/4 inch shelves what would be the best way to set these three things up on shelves using the balls or not using the balls??????two shelves or three?????eventually going to add components as well blue ray,power conditioner,amp etc...???
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post edited by K-daugh on
There is a current thread that is addressing this very issue. I would suggest you check it out. It has some good information.
http://www.polkaudio.com/forums/showthread.php?t=101926&highlight=tennis -
zingo beat me to it!
very good guys any ideas for my shelves though should i give each component its own?Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
