2 CSi 5???
there is a used good condition CSi 5 center that i can get for $100. good price considering I paid nearly $200 for a refur/new direct from polk ebay. But right now, I already have CSi5/Rti8s setup. What do you think if i add another one to the system? would it sound and look overkill?
yes, I have enough power and space for them all. right now I am using a 5 channel HK PA5800 amp 80wpc
Post edited by nhhiep on
I guess my first question is why exactly do you want two center channels? You would be better off getting a bigger amp than 80wpc.
i think 80wpc of HK brand is enough to drive them. they're easy to drive afterall.
You could use one of them as a rear center in a 6.1 set-up.
HK underrates their gear. 80WPC from HK is plentyMy System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
What application do you have in mind for the second CSi5? A second center channel?
If so, I'd say it'd be a waste of time IMO. Using multiple center channels is an invitation for phasing and cancellation issues...and it isn't really necessary. A single CSi5 is MORE than capable of carrying out center channel duty.
You'd get a bigger improvement from upgrading your amplification IMO. HK might underrate their gear, but 80 wpc still isn't a whole lot. Wattage isn't everything though, of course. I've found that the 100 wpc from my Adcom 545 is sufficient for nearly all of my 2 channel listening.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
for $100 buy it and try it out. If you don't like the sound then you could always sell it.
I have a rear center channel, 6.1 set up.. It lets me receive the EX listening mode on my avr. I thought about setting up 7.1 vs 5.1 and the 6.1 was a happy compromise.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand -
to bring up this old topic. I didn't buy that one. but today saw another one on CL for $75. really want to buy it to use the extra channel on the amp that I am not using anyway. I would think 2 CSI5s combined equal a killer center with 4 6.5" woofers and 2 tweeters...the idea of having a center with that many drivers is mouth watering.
but comfortablycurt said something about cancellation above.... anyone care to explain more....if 2 speakers are identical and wire the same. how are they cancelling out each other?
