How can i De-Troll my internets?
Pauly
Pauly Posts: 4,519
edited May 2010 in The Clubhouse
Nice Article
Check it
http://lifehacker.com/5547607/how-can-i-de+troll-my-internet
My favorite part
Do Not Feed the Trolls
Apart from that, the most important advice we can give is whatever you do, don't feed the trolls. Trolls thrive on getting a rise out of people, and if you reply to their comments, you're just giving them the attention they so desperately crave. And, if you respond in a negative tone, you end up becoming just as bad as them and fan the flame war, so to speak. Be sure that you're setting a good example and adhering to the best netiquette practices.
Our most important suggestion: The best thing you can do is learn to deal with, and when necessary, entirely ignore the trolls. Unfortunately, it's something we all have to do, both in real life and on the internet, and while there are certain tools to help you avoid them completely (depending on the site), no solution is sweeping and foolproof, so the best way to get past it is to hold your head high and power through.
Pauly
Life without music would
Post edited by Pauly on
  • ohskigod
    ohskigod Posts: 6,502
    edited May 2010
    http://www.youtube.com/watch?v=FMEe7JqBgvg
    perfect video about internet trolls, can not be embedded unfortunatly. bleeped out curse words"
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • Jstas
    Jstas Posts: 14,808
    edited May 2010
    That was funny! I can't believe they actually referenced usenet!
    Expert Moron Extraordinaire
  • concealer404
    concealer404 Posts: 7,440
    edited May 2010
    Now if i could figure out how to "De-Justin Bieber" my internets....
    OH WAIT!!!!
    http://fffff.at/shaved-bieber
  • cstmar01
    cstmar01 Posts: 4,424
    edited May 2010
    OH WAIT!!!!
    only you would have that problem :p
  • hearingimpared
    hearingimpared Posts: 21,137
    edited May 2010
    ohskigod wrote: »
    Did you edit your last comment or was it done for you?
