Identify RD2505-1/2 8" woofer
HB27
HB27 Posts: 1,518
edited May 2010 in Speakers
Cleaning cabinets and I don't remember what this driver is out of.
Thanks for the help.
Harry
  • mdschlayer
    used in LSi15 tower and PSW250 HT sub
    LSi15's, LSiC, LSiF/x's, LSi7's, vr3 crossover upgrades, SVS PC-12 Plus, SVS SB-16 Ultra, Marantz AV8805, Parasound amps, LG OLED65C9PUA, Clarus Crimson, Signal Cable, Atlas Cable, Shunyata and Synergistic A/C conditioning, dedicated Cardas 30A and Furutech 20A AC lines, Box Furniture, Solid Tech ROS, Symposium roller blocks
  • indyhawg
    indyhawg Posts: 1,683
    edited January 2019
    A thread started by Harry resurrected. I miss that old guy. He is the one who turned me onto this forum. B)
  • skrol
    skrol Posts: 3,497
    Hey I wonder if the PSW250 would benefit from the same DB840 woofer upgrade?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • bauhau
    hi all, landed here after a long (failed) search for a new 4 ohm, 8 inch, RD-2505 for an LSi15.
    does anyone know either how to get one, or another speaker to try -i was told by a local speaker geek there are some good alternatives, but then he disappeared ..
