2-Channel Receiver Opinions
Ethancf
Ethancf Posts: 478
edited May 2010 in Electronics
Hey all,
Could you guys provide some insight regarding good some good 2-channel receivers? Doesn't need to be anything high end by any means. This will be for a living room system...low to medium volume most of the time.
Thanks,
Jason
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    Look on ebay for Harmon direct. They have great deals on refurbs.
    Ben
  • ben62670
    edited May 2010
    Ben
    edited May 2010
    Harmans are a very good choice at a good price, +1!
    A bit lower on the list would be the Onkyos (TX-8555) or an older model--not quite as warm or refined as the HK but they have enough power.
    Another good choice would be the Marantz lines..SR4023 or older models in that series
    Or a used NAD C 725BEE! It really depends on what you want to spend? And how much power you need?
