compairing M70s to Cerwin Vega floors....please help me out.
101mph62
101mph62 Posts: 11
edited May 2010 in Speakers
I have a set of M70s that I'm using and a friend has a set of Cerwin Vega V-12f. Now I can not find to much out about them other then:
V-12f
Frequency Response: 28 Hz - 20 kHz
Recommend Power: 10 - 300 watts
Sensitivity: 98 dB
Impedance: 8 Compatible
Protection: Self-Resetting PTC (Tweeter)
Video Shielding: No
Dimensions (H x W x D): 34" x 13 5/8" x 14 1/4" (86.4 x 34.6 x 36.2cm)
Weight: 49 lb./22.2 kg
Finish: Gray Granite Vinyl
1 12 inch sub, 1 6/2 and 1 tweeter
Now we both are using a onkyo 707, are my polks better sounding compaired to his? Looking at the specs they look to be about the same? Am I missing something?
Post edited by 101mph62 on
  • Pycroft
    Pycroft Posts: 1,961
    edited May 2010
    The way a speaker sounds cannot be determined by specs. I have heard a number of Cerwin Vega speakers, and I'd say the Polks would sound WAY better - maybe not louder, but better. The only person that can judge that is you, and your ears.
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
    edited May 2010
    I have to agree with James there. What you WILL hear is that the C-Vegas will sound LOUDER at the same volume setting because they are more efficient. You will also hear lower bass notes because that's what CV is all about....big drivers, square cabinet, party sound. But in terms of 'quality' of sound--the highs, the mids, the tightness of the bass, etc. the Polks should yield more and better detail, soundstage and imaging, etc.
    Listen closely and 'you' will hear the differences yourself. CVs are a pretty 'muddy' sounding speaker with a veil over their highs and a non-distinct midrange. But they can put out some serious SPLs....if nothing esle.
    Enjoy your Polks!
    cnh
  • George Grand
    George Grand Posts: 12,256
    edited May 2010
    Go to the library and get a book on audio.
  • inazsully
    inazsully Posts: 21
    edited May 2010
    George, only somebody with 7500 posts would give that advice to someone asking for an opinion.
  • halo71
    halo71 Posts: 4,640
    edited May 2010
    101mph62 wrote: »
    Forget specs and trust your own ears.
    A friend of mine has a set of those CV's and they sound like ****$ to me. No definition, sound stage etc etc. Now if you want to piss off the neighbors. These are your speakers! :D
    --Gary--
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2010
    IMO, the Polk's would probably sound better. I've heard a lot of CV's in the past, and I've never been real impressed by them. As others have mentioned, CV's are SPL queens. You can crank them to the moon without even trying, and they'll pressurize a room with some really deep bass response. Aside from those two things though, the SQ just isn't there. Tinny sounding, inaccurate highs...midrange that's kind of on the dry side. Just kind of a "loose" overall sound.
    That said, you can't tell which will sound better by the specs. If you can, try to compare the two side by side.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
